Tax Time! Post Cool Stuff You Bought
3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
