  • Replies 90
yeh it was really nice on Saturday night/Sunday morning, we left at around midnight did speed limits all the way to berowra was the 1st time i was able to drive the GTR on a good road other then to and from work so im pretty devastated about it. 1st time i gave it a bit and it went
After reading your thread and current situation, my suggestions for your car and it's use (big thing here is keeping constant oil pressure and oil around the oil pickup):
Stock gtr oil pump, because n1 will pump more oil out of sump regardless of restrictor.
tomei or similar baffle kit with restrictor, plus .5-1L overfill on oil. I put 6L in mine every oil change.
Mines style cam cover baffle kit.
It will live a happy life, but the stuff I reccomended is your choice in the end.
sigh i feel like i have died on the inside.
I am really out of my league with this sort of stuff and im lost, but i think what u said sean makes seance to me, im not going to be running huge boost or power so there is no point in doing the forged internals thats just a waste of cash on the parts and the machine work. If i was to do what you suggested would you happen to know all the parts i would need besides the Baffle pans, pump and bearings?
and is this the cam baffle u where talking about?
http://www.nengun.com/mines/triple-flow-cam-cover-baffle-plate
Edited by T4NK
ok so my list is
Engine======
Bearings
Gasket set
Timing belt (may as well do it with engine out)
Water pump (may as well do it with engine out)
oil delivery====
Sump Baffle
Cam Baffle
Oil Restrictor
Oil pump
hmm well this is a very steep learning curb for me, other option is to fix what is broke and sell her, as sad as i will be
As above, at least get some new genuine rings for the pistons as well.
Shouldn't cost too much.
Also get new timing belt tensioner bearings (because the wear and dry out) and a new tensioner stud, as studs are known to break.
And make sure everything gets cleaned out really well. Ball bearing turbos hate any sort of metal debris in them...
Shop around/ check for sale threads for best deals too.
Ps. Why on earth would you make your GTR a daily, thats just asking for trouble lol !
would have to agree with this 100%.. its not impossible, but far better if you dont have to rely on a car like this as your primary mode of transport unfortunately..
keep us posted, best of luck to you mate..
Mine is a daily i dont see a problem with it being a daily
Everyone's worst nightmare man. Tuff luck. Get it back on the road and enjoy it.
I know u want it as a daily but it's a risky thing man.
I had mine as a daily for a bit and hated putting so many kms on it. The bug will bite mate it's just a matter of time.
I ended up buying a pos daily for $500 to get to work and back. I absolutely love being able to leave my baby in my garage for weekend ls etc. prob the best thing I ever did was buy the daily.
Yeh im waiting on a price to do the oil system and clean the block out and replace bearings, i think this is the best option for me, im also seeing if i can borrow a car from my parents for a few months, if only this happend in 3 months time i would have been ok but 2 weeks after i bought the car, i also think the guy i got it from knew it was shagged as he has not returned any txts or calls and i still have his peronalised numberplates that he wanted me to send back.
Feel your pain, i will be pretty pissed. If this happens to me. luckily mine is weekender only, although do get driven on the odd spirited drive. let us know what you end up doing and how much a standard build cost. everyone talk about big forged builds, but not everyone needs that kind of engine if your keeping it stockish.
Im going to to a forged build but i think im going to use the same size pistons to try to cut down labour on it, im going to have to garrage it for 2-3 months b4 i can do it and ill pay cash for it. I need this thing to be bullet proof, not for big power but for reliablity as i want to use it as a daily. im doing around 120km a day atm but i will be moving closer to my work in the next 6 months so this will cut right down, i just want to enjoy the car and not have to worry about blowing it out again so doing it right the 1st time. Im looking at getting power tune or the shop on the coast to do it at this point depends who can give me the best price and service.
I was in the same situation of wanting to rebuild it for strength and longevity and only use the stock Nissan parts.
But Racepace explained and justified to me how they rebuild their RB26's and forging is the best.
As well as forging, refinement / customisation / balancing the parts and improving the whole engines setup.
Which leads to Strength / Longevity / With-stand High Power Applications = Bullet proof.
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
