i think it really comes down what your block looks like - if you bores are fine, keep the stock pistons - just replace the rings etc. But if you got scarring and sh*t on the bore, then you may want consider a bore out to 86.5mm which will mean A/m pistons.
You've mentioned you want to keep it reliable - although it may cost a bit more, doing a little extra then what your've got listed should give you a fairly bullet proof engine.
are you pulling the engine out before you sent it to the shop or are you getting the workshop to do everything?
  • Replies 90
This thread has gone from bad to worse.
Now it's up to not using .20thou pistons to save money? Bore and hone is $180!!!! Oversized pistons are the same cost as stock sized.
Would you like to do it once correctly and have it last, or skimp on vital things and be wondering in 6 months why it's died again?
Just save your coin and take it to an RB shop who knows what they're doing, let them do what's needed and then pay the bill.
Edit: not trying to sound like an ass, just seen this happen before.....a lot
Also heres something to consider; there's now going to be tiny bits of bearing material throughout the oil, all of the oil.
So anywhere the oil goes (engine of course but oil cooler too), needs to be cleaned out properly. So cooler core and the part you may not have thought of yet, the head. A head service isn't a big deal while the engine is apart but it's like anything and not free.
If you just pull the engine out, pull the sump off, and try to swap bearings (you'll have to pull the crank out to machine it), then put it all back together the problem is you don't know how much bearing material is in the head waiting to wreck your day soon.
I'm happy to help as I have for others in this position but not if you won't allow it to be done properly the first time.
I am getting a Nissan N1 pump for my build.
But that's just me staying with Nissan parts.
And it can handle the power you want for you build and a lot more if you decide to tune up for more power.
If you have the money go the Tomei or Nitto but as you mentioned cash is a slight issue atm so just go the N1. They are a good pump regardless of some of the things that you might read on the forum about them.
For your power goals it will be perfect and give you room to play with if you decide to down the track.
Ps dont forget your oil restrictor ! :)
I know of at least of 3 people running unmodified N1's in their big single Rb26 drift cars that see regular limiter bashing at high 300 - low 400kw and they do just fine.
Too many people are too quick to bag them out imo.
The car is getting
CP Pistons
Manly Turbo tough rods 1000hp
Tomei Head gasket
Tomei Baffle pan
Mines Cam baffle
Tomei Oil restrictor
ACL bearings
studs
Tomei valve springs
Gates racing timeing belt kit
Gasket kit
probs more that i cant think of but thats the main guts of it. i will see how i go when it gets closer to it, its around about 1k more for the nitto pump if i can strech it out then ill bag that or go the N1 if i cant.
Edited by T4NK
Only alterations might be Nismo belt and Nitto pump.
Ever seen a cutaway comparison of a N1 pump Vs Nitto?
I have an N1 oil pump. It's behaving itself.
My son's VS2 Nur has had its N1 pump changed to a Nitto just for precautionary reasons (by the previous owner).
My $0.02 - I think alot of it comes done to who builds the engine and how anal they are about bearing/general clearences/tolerences. I beleive Its the shock loading caused by excissive clearence between the colour and gears that cause the pumps to fatique crack and fail...This can happen in all pumps, but its more prenounced in the n1's & stockers due to the relative strength of the material (sintered metal vs say en24(or there abouts) for the nitto). One day, i'll sit down and run an FEA analyse on a few of the pump designs to show the weak points in the designs.
However, IMOH all pumps will work in the hands of a compentent engine builder. The tomei/nitto just offer an additional safety factor.
If you do go down the tomie/nitto route, i strongly recommend getting a sump extension to 8L and baffels installed to prevent oil starvation due to the higher pump flow rate.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
