  • Replies 57
Sorry Domino, been a bit caught up with Targa Adelaide and all the associated work :)
This one is on the front-burner from here on in until completion. One of the 'tricks' we worked out is that to install the Greddy turbo kit you must have a Greddy top pipe kit as well! Thats done now.....
SD tuning only in something of this 'size'
This package has probably the best flywheel setup their is....we totally re-engineered the whole thing so that never, ever in its life can this GTR ever make another flywheel rattle noise. From that point of view it behaves like a normal car.
The noise you hear is the engine/turbos as it doesnt have an exhaust on in the video, its straight out the dump pipes :)
Just wouldn't be a GT-R without the rattles :P
this is interesting - how does the flywheel become 'loose' & why?
assuming the flywheel bolts run straight into the rear of the crank like a conventional engine - are the actual bolts under engineered or not correctly torqued from factory?
i'd stop at full bolts on and mod'd stock turbos, and spend the rest on a set of A005's for the stock 20's for such events
pretty sure Martin and Seb have run A005s iirc - Martin could you get away with A005s on rear wheels only and stock bridgestones up front?
Edited by domino_z
Arent they slicks? If they are they are not allowed. There must be a perfect combination of power vs traction for this type of event. Road surface will obviously be a variable factor. It would seem that Martins WR600 was better suited than Seb's setup.
Edited by g35me
Temora was all about traction over time.
Sebs Alpha 12 was easily faster than the WR600 through the acceleration increments once it had achieved full traction, however finding that traction balance was difficult on the day. It didnt help that Sebs car was running Dunlop road tyres where the WR600 was using the SportMaxx version (as a test, which worked well)
Towards the end of the day when Seb really got into the car it was indeed faster in elapsed time than the WR600 head to head however the track had gone off to the point where no more fast times were run. On a dragstrip it would have been a very different story - as you might expect.
Temora is no real test of car performance rather the ability to adapt to the surface.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
