Hi Guys,
Has anyone earthed Pin 60 from the PFC in order to fix the dreaded R32 GTR Misfire issue?
I just want to know, when you earthed it, did you cut the wire entirely and earth it straight from the PFC? Or did you splice in an earth?
I tried splicing in an earth and the car started to idle very roughly and i'm a bit cautious to cut the wire entirely to test a direct earth.
Thanks,
Taran.
https://www.sau.com.au/forums/topic/405358-r32-gtr-earthing-pin-60-on-pfc/
I was told by other skyline people that running other than OEM coil packs can cause the hiccup. But I don't think so... And another thing I've been told was that the power fc needs a constant voltage and if it drops below that then it causes the hiccup.
But I can't confirm or deny any of that sh!t.
Alright guys. I grounded pin 60 directly using a very clean ground and it failed. It made the idle really lumpy and rough so now i'm back to how it was before.
Anyone have any other ideas?
The capacitor sounds interesting. How would we implement it?
Update. So i drove the car yesterday and the misfire is gone. Will have to drive it a bit longer to confirm it but so far so good. If it's permanently gone then it means it was the ignition fuse, near where the 4wd fuse is under the bonnet. The new fuse i picked up from SSS Auto looks like a newer type, it sticks out a bit more and the fuse link looks much fresher than the previous one. Perhaps this could have been it? What kind of fuses do you guys have in yours and what model GTR's do you have?
The fuse thing could be the fix. Maybe after X years they get brittle.
I put a USB charger in my ciggy lighter, and when u plugged a USB cable into it the fuse blew. Thinking it was a broken item to start with, but tested it again with a brand new fuse, and its been fine ever since. So it is possible that maybe the fuses are causing a bit of resistance?
i think so but its not at all bad. ill be cruising along everything perfect then BANG the car will just kinda like hit limiter or something scares the absolute shit outta me. then thats all, it goes without a trace. does it once every 2nd drive say. just got new 30a fuses the old ones have alot of green scum on the copper through the clear plastic.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
