I am looking to buy a hks 2530 turbo or my 32, having trouble finding one anywhere, will also consider a 2535 aswell, im from nsw, newcastle region, happy to pay postage and decent money for the right turbo.
Cheers guys
https://www.sau.com.au/forums/topic/405466-wtb-hks-2530/
hey mate the hks 2530 is pretty much a re branded garrett 2860 and garrett are a bit cheaper and alot easier to come by the only diffrence is the hks spools a little bit quicker but not much youll bearly notice..
unless your looking at getting the 2530 external gated then ignore all above haha
https://www.sau.com.au/forums/topic/405466-wtb-hks-2530/#findComment-6457587
Ahk thats good to know, yer im looking at getting the hks 2530 with external gate, just trying to keep everything the same? Whats the difference between external and internal gate, as far as installing wise and stuff? I take it the garet 2860 is internal gate?
https://www.sau.com.au/forums/topic/405466-wtb-hks-2530/#findComment-6457819
Yer the garrett is internal, is this for a gtr? so twins? or just single?,,,the 2860 -7,-5,-10 turbos and yes there in that order smallest to largest there a turbo made by garrett for the gtrs they have the t25 flanges so there a direct bolt on to the stock manifold..as for the diff between internal and external waste gates im still fairly noobish but as far as i know an internal gated turbo has an inbuilt waste gate and actuator on the turbo, a external gated turbo the waste gate is fitted to the manifold as apose to being on the turbo it self, as for the fitting for an external gate if its for a single set up youll need a custom manifold with a tial vband for the waste gate the be placed your better off talking to 6boost about this stuff because its there bread and butter and i have yet see a better made manifold youll find them in the buisness section
https://www.sau.com.au/forums/topic/405466-wtb-hks-2530/#findComment-6459539
Its only for a gtst Single turbo. Yer i thought i might have run into some dramas, thats why ill just still with the external gate for now, so much less hassel is what im after haha, its hard enough finding a turbo!
https://www.sau.com.au/forums/topic/405466-wtb-hks-2530/#findComment-6460106
Whats the difference compared to hks2530
hardly any. responsive 250rw
Actually the difference is in the detail, it's defnately not as direct fit as a hks2530 in the fact it has a 3" inlet compared to the hks Oem/direct fit intake, also the 2871R is marginally less responsive but produces higher output...
Comes down to the following, wheels sizes/trim & housing a/r...
Hks2350 .60/.64 smaller wheels
Gt2871r .60./.86 larger wheels
GT2871r rated to 390hp(48 trim) or 440hp(56 trim) is closer to the GT-RS from the hks family...
A garrett gt28rs (rated to 350hp) is as close as youll get to a gt2530/gt2535 from hks that your looking for...And at around $1400 or so new is really hard to argue with asits brand new with warranty. Just make sure you specify to the supplier you a after the skyline oem t3 6 bolt rear housing...
Edited by krayzie32
https://www.sau.com.au/forums/topic/405466-wtb-hks-2530/#findComment-6465297
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
