Hey guys im new here :no:
just a quick question. my r33 gtst is blowing a lot of white smoke. it would literately fill my whole street full of smoke.
I have taken it to ultratune and they have done a compression and leak test and it came back ok. they are learning more towards a turbo issue. but they are still unsure.
is this a common thing for skylines?
if it is indeed a turbo issue they are going to upgrade to a high flow garret turbo, which leads me to my next question. how much power is this thing going to output once its installed?
specs of car
Front mount intercooler
pod air fillter
full hks exhaust
boost controller
and the garret high flow turbo.
thanks guys.
lol
seems like youve done ur bpu , so OBVIOUSLY depending on how many pounds you are running , id say anywhere from 200 - 230rwkw. youd also need to get a tune though to get this kind of power safely
Yes white smoke is usually a turbo issue if its a large amount of white smoke and the compression test came out ok.
Edited by tripsteady
  • 3 weeks later...
Hey guys...remember me? :P
wasnt the turbo...it was infact...a god damn cracked piston. 7grand later.....sigh
on the plus side. since I had the engine out...I went all out.
port and polish
overbored
ngk spark plugs
high end metal gasket
high flow garret turbocharger
new ecu
wiseco forged pistons
running 18psi boost
my mechanic thinks it will pump over 350kw at the wheels. getting it dyno tuned tomorrow with vid :)
will update tomorrow tomorrow.
so any more info on the turbo? might be a good idea to do some research on here before you spend that much coin.
every turbo will have a different result and will make the car perform very differently
Hey buddy
Its my standard turbo high flowed with garret internals. cost me $1500
still need it tuned on the dyno. not sure if I need a new ecu? cant really afford anything after spending 8grand :(
I just hope my mechanic wasnt taking me for a ride. just seems so exsessive...I mean, 8 grand? :(
drove the car all weekend to run in the new pistons. didn't boost hard, but I can already feel the car is alot more punchier and responsive.
will update soon. any advice is appreciated guys :)
My mechanic said he is going to try his best to tune it with the stock ecu. he said the car is still going to be pretty quick as it is. he is a professional drag racer so Id like to think I can trust him. he seems like an awesome guy though.
will save up for ecu later down the track
