so im looking at buying a set of these achilles 123 semi's. as there a street tire i dont think there really a real semi slick but thats what they call them. so im wondering if anyone has used them and can tell what there like in the dry and wet. there pretty cheap around $220 each. trying to compare them to the rsr and ku36 with a better tread wear.
Dunno about the semi sliks but my mate just replaced a set of Achillies road tyres on his wifes commodore that did less that 5,000kms before they were rooted... I think they are a pretty cheap shitty brand.
I was looking at trying them too... Most I've asked said they are on par with the other two choices... There are drift cars and track cars using them successfully, they are a street tyre like the others and should be fine.... As for the commo wearing them in 5000km, well it's a commo.... :P
I don't know their semi slick at all, but for a cheap tyre I was very impressed with their street tyre's grip. The extra wear Chris was seeing might be related to being softer/better grip than the usual chinese rock-hard tyre that lasts for 1billion klm but has no grip.
Nope, they will be along the lines of the KU36 and RS-R, a real grippy tyre for street.... I assume these will suck in the wet too.... My KU36 have done over 5000kms and are only wearing due to no wheel alignment since suspension work, they have a similar tread wear to the 123s I believe
Don't be fooled into getting these tyres, I have these horseshit tyres on the R33 I just bought, the rears are 275 wide and the car is stock, and I have crap all grip.
I ran smaller 255 KU31s on my old 240rwkW R33 and it provided more grip.
not to mention I have a friend with a mirage using the same tyres and he lights up 3rd gear with ease, well he is running an EVO 5 motor but that's not the point lol
Edited by johnnilicte
And yet SimonS14 and a couple of the other drift guys all rave about their grip?
it's like someone saying Linglong tyres provide hectic grip, try them out for yourself LOL... yashimash!
Are you sure you didnt use the achilles atr sport? because Ive also used the 123 and they are on par with the rsr in terms of grip.
Achilles 123 aren't sold in a 275 tyre as far as I'm aware also... :/
Danny Vahoumis drifts with the Achilles 123 also and it's apparently a pretty decent tyre.
I have 123s on my Evo 8 and I would recommend them to anyone. Great tyre for the price. In the dry they grip better than my toyo r1rs and federal 595 rsr. For the fella that spins 275s like the car is 500 horsepower... Your car suspension would be set up like a pile of sh*t.. That or you're driving in the wet clutch popping every two minutes.
Probably is too, just bought the car and it's running some rubbish pedders comfort shocks & springs, soon to be removed and put on eBay.
As for the clutch popping every two minutes, I'm not 18.
Can you confirm you're running 123's? What size are they if you are, cos you're not running 275's.
I'll look when I get home, they provide very bad lateral grip I can tell you! The car would come out around corners in a tight roundabout with some gas.
Could be a heap of reasons for that though!
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
