Okay I came back because I feel bad...
Bike sounds like a good idea.
Do what I am currently doing and for lunch cook up some chicken + broc
If you prep your meals it will help you A LOT!
Keeps you on track.
The days I dont prep I find myself going ehh may as well just get this.
and look down and I am eating some fat burger
My biggest problem...
Dont like any vegetables.
Salads, sort of ok, but not veg.
Closest i get to veges, are hot chips, because theyre potato.
Used to be the same on the vegetable subject.
Then I became a man.
It's no longer an issue.
This. Have had brocolli/cauliflower boiled for dinner maybe 3-4x a week for the past couple of years, minus 3ish months (binge).
Do it, after a while you'll get used to it... :yes:
im competitive and like numbers so install 'runkeeper' and use it to improve your walk/run/ride.
Disclaimer: the furthest ive gotten is installing the app :)
thanks.
is that for iphail, android, or both?
I had an app called noom that wasn't too bad, might have to get it back
  • 3 weeks later...
Ok, back in the band wagon, exercise wise.
still eating crap.
went for a 2k walk yesterday arvo.
today was a 1.6k walk, the 30mins on the cross trainer.
feeling pretty good.
cracked the 1.5l mark of water intake, considering I normally only drink soft drink, this is quite an achievement for me.
  • 4 months later...
  • 4 weeks later...
