Details
Car: 1995 s1 r33 gtst rb25
Mods: exhaust and pod filter
Recently brought and have been putting bp ultimate premium 98 in it and have been told its spitting fuel out the exhaust and I constantly back fire and split flames. I get approximetly 300-350kms from a tank im not sure whats normal.
Does anyone know any reasons it would be running rich?
Maybe its not tuned to ultimate premium 98? If so should I put 98 or 95before through it to see which runs better? Thanks in advance for help
https://www.sau.com.au/forums/topic/406076-reasons-for-running-rich/
Have to remove the top timing belt cover. Align the crank pulley with TDC and then check cams are aligned with there corresponding marks.
Be aware that to remove the top timing cover u need to remove the crank sensor, this is in a certain position and is very inportant. Either mark its current position before removing. Or better yet check with a timing light before removing (engine at operating temp) then reset to the same after refitting
your timing will bounce around a little bit. that is normal. the raw fuel and flames may be caused by the timing being physically out (such as a jumped tooth on the timing belt), but it may just be that there is a more simple reason. i'm guessing that your catalytic converter is probably hollow (as that allows flames a lot more), but it may also just be that you have a fuel supply issue, caused by a fouled injector, AFM reading wrong, or an intake leak. or possibly even something like the thermostat not closing properly (causing the car to run too cold) can affect the fuel economy. if the car takes more than about 5 mins of driving for the temp needle to start to get to around the middle of the gauge (or it never does and only stays around the bottom of the gauge) then start by replacing the thermostat and you will find that the car runs better and uses less fuel.
how many litres are you classing as "a tank" as that will give a better indication of your fuel economy and just how rich it is running. your driving style will play a big part.
i used to only get about 17L/100kms out of my r33 gts-t, but i had a bit of a lead foot. regular boosting, etc.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
