I have installed 1DIN DVD/MP3/DivX player in upper glove box of my '06 CPV35. In place of DVD NAV unit.
Have to tell ya , it's not that easy as it sounds...
Thanks everyone on the forum for sharing installation tips etc... thought I'd give something back.
Bose Sounds amazing...video didn't work though :O((
Monitor was switching to JAP map with crappy message popping up all the time...
After spending a night in the garage and getting sore back I finally found the solution, some of you might be interested in.
The Fix is for Series II V35 DVD NAV unit.
Model Number: CCU-3403M
Part Name: CONT ASSY-NAVI
32pin harness:
Pin-4 (Blue/Black) Cut or better wire to a switch as I did.
Pin-5 (Pink/Red) Connect to Ground.
https://www.sau.com.au/forums/topic/406198-dvd-nav-fix/
This is not correct. When i did mine pin 8 is the speed sensor which needs to be put to a switch. But i cant find the park brake which needs to be cut in the wiring diagram. I found this by probing all the wires (use LED test light) while putting the park brake on and off. From memory its pretty close to the speed sensor wire. When you find it, just ground it.
pin 9 is illumination.....
https://www.sau.com.au/forums/topic/406198-dvd-nav-fix/#findComment-6472949
Series 1 is the white plug,
Pin 7 the purple with the white dot is the handbrake which gets cut and earthed
Pin 8 is the speed sensor which just needs to be cut. I would only put a switch there if you want to keep the screen functions working
The easiest solution would be to get it done programmatic-ally
https://www.sau.com.au/forums/topic/406198-dvd-nav-fix/#findComment-6473335
  • 3 months later...
So If the speed sensor wire is cut the screen functions would not work?
https://www.sau.com.au/forums/topic/406198-dvd-nav-fix/#findComment-6618650
I believe only in terms of mileage, maintenance schedules, and anything else that needs to measure distance travelled. Otherwise, all other functions not related to distances/speed will continue to work.
https://www.sau.com.au/forums/topic/406198-dvd-nav-fix/#findComment-6619483
  • 1 year later...
Arh SWEET so the module is under the passenger glove box area?? :yes: I was going to just splice/ground the park brake wire actually at the park brake,
but if its easier to do from the passenger module thingy even better, as I was going to do the speed sense wire also if I could find it! So that wire is
a BLUE/BLACK STRIPE RIGHT, How would one test you have the speed sense wire?
Excuse my ignorance here, im not a wiring techy at all. So by cutting the speed sense wire you can always watch video/screen function whilst on the move? A switch which some are putting in is for turning the screen off whilst driving right?
:unsure: Isnt the reason for cutting it in the first place is to use the screen on the move? Bascially just wondering why a switch?
https://www.sau.com.au/forums/topic/406198-dvd-nav-fix/#findComment-7190820
The switch is to cut the speed sensor otherwise the screen will be blocked as soon as you start driving.
The switch is there so you can still have the use of the trip computer when not using the screen.
The easy fix is just get it converted to English with the video block removed in the program.
https://www.sau.com.au/forums/topic/406198-dvd-nav-fix/#findComment-7192430
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
