So far the only parts gone are:
- Gearbox
- Brakes
- Rear Hubs
- Diff
I'm stripping it down over the next few days, From a quick look its pretty much standard with a FMIC and 3.5" exhaust. Interior is mint.
Best to call or text me on 0435262590. I'll be getting rid of the car by Tuesday arvo so any sought after parts i'll put aside anything else you'll need to give me the heads up and pull it out and put it aside.
If you want pictures or info let me know.
Cheers,
Kurt.
https://www.sau.com.au/forums/topic/406270-tas-wrecking-s1-turbo-r33/
Do you have the front bumper liners? the ones that attach to the bumper and sit in the wheel arch?
I'll take those if you still have them and are willing to post to Perth.
Like these ones pictured in the below link, not the smaller fender liners though (I already have those), the bigger ones behind them are the ones I need.
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=218901
hey, do you have perfectly working front hubs (no noise), washer bottle with motors, both front seats? also a price on all that thanks, I live in hobart so no delivery needed :)
Replied to your text Beau. Everyone else i haven't got back to yet i'll try to in a moment. Any one chasing things let me know as im out of the state soon and would rather organise it before i go so i dont have to put the reli's out of there way.
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
