disco_potatoe Posted August 5, 2012 Share Posted August 5, 2012 Hi all, just wondering if anyone has installed a Nismo short shifter before and what is there thought on it? I'm looking at installing it into my r33 gtst which has a cushion button clutch. So just after some feed back on the feel and what advantage this install has to offer. Any information would be fantastic thank you very much. Link to comment https://www.sau.com.au/forums/topic/406325-nismo-short-shifter/ Share on other sites More sharing options...
MrStabby Posted August 6, 2012 Share Posted August 6, 2012 Short shifters reduce the distance that you move the shifter, as they change the pivot height (so less leaveage). Seems a bit odd to be considering one, when you're not sure what it does...?? Anyways Nismo have two types, one that's around $250 with offers 10% reduction in throw, and one that's about $600 that offers 25% reduction. The 10% one is barely short, it just sort of tightens up the feel a bit. The 25% you'll really notice the throw is shorter and stiffer. Link to comment https://www.sau.com.au/forums/topic/406325-nismo-short-shifter/#findComment-6475530 Share on other sites More sharing options...
disco_potatoe Posted August 6, 2012 Author Share Posted August 6, 2012 Where would you recommend buying one from? Thank you for your information. Link to comment https://www.sau.com.au/forums/topic/406325-nismo-short-shifter/#findComment-6476372 Share on other sites More sharing options...
Moodles2 Posted August 6, 2012 Share Posted August 6, 2012 Note that speeding up the shifting process puts more strain on the gearbox and will likely crunch gears if it isn't already Link to comment https://www.sau.com.au/forums/topic/406325-nismo-short-shifter/#findComment-6476639 Share on other sites More sharing options...
R31Nismoid Posted August 6, 2012 Share Posted August 6, 2012 Note that speeding up the shifting process puts more strain on the gearbox and will likely crunch gears if it isn't already Exactly. You can outshift the box with the factory throw distance, putting in a short shifter just makes it worse. I actually removed my short shifter many years ago for this reason. Whilst it was cool when putting round the street, when racing it would constantly lead to missed/crunched gears as you can only shift so fast. Stock throw back in, never had a problem after that. Link to comment https://www.sau.com.au/forums/topic/406325-nismo-short-shifter/#findComment-6476693 Share on other sites More sharing options...
WMDC35 Posted August 9, 2012 Share Posted August 9, 2012 Nengun has them if you're still going for it Link to comment https://www.sau.com.au/forums/topic/406325-nismo-short-shifter/#findComment-6479753 Share on other sites More sharing options...
