Justin's Pie Cruise! Sept 16Th Robertson Pie Shop!
  • Replies 98
Posted Images
Final head count?
- Juz
- Owens
- SiR_RB
- Tai1or Made
- pbk1776
- spacepants_fb
- port3s
- levinboy
- Spence_R32
- luke GTR
- xntrq
- virgin white
- Humbla
- arrydjay
- blkgts25t
- crashdown
- ianjb
- Bodella
- SiNNO
- vorse
- FeZ25
Should be an awesome day! >: D
Something I learnt last time. If it's your first time, or a more cautious driver, or have a slower car (GTS-T / GTT is classed as this) then hang to the back when the pack leaves APR.
I was 3rd or 4th in the Q last time and let me tell you, there's nothing worse than having a purple GTR up your arse 1/2 the mountain then having him put you to shame when the overtaking lane appears.
No laws where broken while creating the above story.
I bought a 2way for work today. if anyone else has one take it, just in case.
Excellent story. Completely fictional >.>
Apologies for the no-show. got into an accident last week and forgot to mention in this thread. I intended to meet up with SiNNO first before hand but had notified him that I wouldn't able to make it.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
