hey i got a r32 gtst wich hasnt been started for 4 years ive cleaned all the tank an put a new pump in as it wasnt working i no have fuel at the engine as i took one of the lines off but now it wont start i have good spark an the engine fires when i spray aero start in it, would it be the injectors are fk$d or could it be the CAS any help would be much appreciated cheers
Obviously a fuel problem if it starts with aero start.
Changed to fuel filter?
Did you connect up the fuel lines correctly when you put the pump cradle back in? Ie not reversed.
I'd start with that, make sure you getting fuel to the rail correctly before looking at the injectors. But yes, they could be blocked.
Do an oil change first as well if you haven't done so already.
Oh, you could also remove the CAS, switch the ignition on, rotate the CAS with your hand and listen to see if the injectors are firing. If they are, it's not a CAS issue.
You can disconnect the fuel pump remove a spark plug and rotate the CAS see if it gets a spark or not. If it does then its probably working. Hook up a fuel pressure gauge see if there is fuel pressure and check the fuel filter.
Yeah you'll still hear them firing even if the are blocked.
Another thing to try, is block the fuel return line with some clamps and then try starting.
Pull the CAS first and check the injectors are firing.
When your cranking it (without aero start), does it fire/cough at all? Or it just cranks?
If fuel is getting past the regulator then you have enough fuel to start the engine. Don't worry about a pressure gauge for now.
Do as suggested above and listen for the sound of the injectors while rotating the CAS with the ignition on. They will be fairly noticeable. If they don't pulse, get an LED test light or a noid light and test for injector pulse. If you have injector pulse, turn the ignition on, get a screw driver and LIGHTLY tap each injector while a mate rotates the CAS. If any of them start ticking after that, take them all out and get them cleaned and flowed
Just adding to that, if you use an LED to test injector pulse, note that you'll need a 12V LED or a 2-3V LED with a dropping resistor. Polarity dependent as well.
Injectors have constant 12V to one side of them.
Injectors drivers inside the ECU ground the other side of the injector.
Im having the same problem. Just put a rb20 in 32 rollin shell. It cranks over and sorta backfires alot but no start. i checked fuel to the rail and thats good. spark is good. First cas i had in it was oviiously f#@ked cause wen i put a spare one in it sounded more like it was gonna fire.first one was makin it sorta die. Ecu code 55 so thats all sweet. All earths seem sweet. Would a few blocked injectors cause wat ive explained or anything else i should check
The injectors will be gummed up, fairly common thing with them. If you have spark then you can rule the CAS out, remove the injectors from the intake but keep all the lines on, then crank the car with the rail removed and check they are working. You probably won't have to get new injectors, generally if you remove each injector from the rail, then gently tap on the injector body with a screw driver this is enough to get the pintle working again.
Then put each one back in the rail. I bought a brand new set of Nismo injectors a while back, had been sitting in there boxes for about 2 years, chucked them in the car but nothing was working. Removed them and tapped on the body, starting working again.
Cheers.
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
