  • Replies 48
cheers V35A wasn't sure if that would be sufficient, but now i think about it i had some led's stuck on with 3m before and went threw auto wash all the time and they stayed on.
@xntrq - some people just prefer the clean no badge look, I know if I owned a GTR I would keep all the badges etc, for me it depends on the vehicle as to wether I would keep them on or not. Every1 is different
sorry to hijack this thread.
I have had a look around on the forums (I do remember a post about it a while back but cant seem to find it anymore) but does anyone know where I could get the rear v35 badges locally (Sydney)? the full set.
Edited by sicz
Not sure about Sydney. Speak to Nuwan from IREV he's in Melbourne but he can get what you want shipped from Japan.
Not local to Sydney, but I see them pop up on ebay in USA often.. remember in USA it is 'cool' to rebadge an infiniti as a Nissan skyline!
The 350GT badge is often there. the 'SKYLINE' letters pop up a bit less often.
Just out of curiosity, I went lengths to rebadge my car. Why would you guys debadge it?
Good point, I have my 350GT fully debadged because i know that i am 1 of 3 V35 owners in my town so i guess it leaves people thinking "damn that's nice, but what is it?" that's my logic anyway. But same as what Joshua says if i had a R series skyline GTR i would leave it badged definitely.
Personally, I don't like the debadged look.. it makes me thing 'dodgy back yard repair job'. But some prefer the debadged look.
Just personal taste I guess.
I get that mentality too. Right now all i have on the rear is the 350GT and i get people ask me what car that is.
Yeah, i just have the front Nissan badge on for the time being until i order a black grill with no badge. It's funny seeing people overtake me and i see them staring at my car, then they get past me and do a 360 in their seat to look at the front badge haha.
^^ 360 degrees? havent seen that since 80's horror films
Ha reminds me of the xbox360 quote http://answers.yahoo.com/question/index?qid=20080814191737AAyxK2j
I can say Annabelle wasn't very bright...
Have you tried, I dunno, Nissan?
Give them your VIN and they can get you the badges... yes, all of them.
yeah the few I called weren't very helpful. The one dealer that had any inclination of getting them in said it would be approx $300!
Tried a couple of local import dealers today as well, none of them had any. So I guess i'm getting them from the US.
Nissan never have any idea about our cars that's why i don't even bother calling them. Last time i went there the head mechanic told me to go to the panel beaters to get my comp rod bushings changed... dafuq
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
