Guys,
Have noticed when I do long trips in stagea every now and then my boost will.go from 9/10 pound to getting restricted to 5pound till I reset ecu via turning off car. No dash warning lights and yes they work. Any ideas guys??
Edited by joshm35
https://www.sau.com.au/forums/topic/406537-m35-boost-issue/
I had a problem with the Boost Solonoid where instead of getting 13psi max boost I would get only 7psi.
My problem had no CEL light and was solved each time by turning the car off and restarting. The cause always seemed to be giving it a few revs up a particular hill.
I changed my Boost solonoid and the problem was solved. The Boost solonoid sits on the passenger side of the car under the plastic engine cover. It is bolted to the side of the plenum and has 2 small rubber hoses running out one side, 1 to the intake and 1 to the turbo actuator and one hose rinning to the front of the car that connects via a T piece to the boost sensor on the intake.
I believe you can clean a solenoid but I did not try that.
Cheers
Andy
https://www.sau.com.au/forums/topic/406537-m35-boost-issue/#findComment-6478256
If the solenoid is blocked it will lower the boost, if there is a leak it may go higher causing the ecu to pull it back.
The hose from the solenoid that T's into the boost line has a restrictor in it. If it has been replaced that could make the boost rise too high causing the same issue. Have you changed the exhaust to 3 inch? that would cause it to run higher too.
A way around it is to trick the stock map sensor into thinking the pressure is fine, you could use a small pressure regulator if you wanted, set to 12psi, but I would be getting a better boost gauge first.
https://www.sau.com.au/forums/topic/406537-m35-boost-issue/#findComment-6478291
i removed the factory one and replaced it with a turbosmart easy 5 mins fix. Boost comes on much better and smoother now.
QFT.
Buy boost gauge
replace with a turbosmart(or the sort) set it to 14psi or whatever the boost setting is and bypass the lines for the standard solenoid. Leave the standard one plugged in to avoid CEL. problem solved.
Edited by Sunkist
https://www.sau.com.au/forums/topic/406537-m35-boost-issue/#findComment-6478382
Cheers
Andy
This sounds exactly whats going on. Do you know the price and numbers of a new solinoid?
https://www.sau.com.au/forums/topic/406537-m35-boost-issue/#findComment-6478525
Standard hoses and exhaust
https://www.sau.com.au/forums/topic/406537-m35-boost-issue/#findComment-6478527
for now? its what I would be doing permanently.. keeping or replacing the solenoid is not going to fix the factory safety drop in boost. it is spiking with the cold weather and/or not allowing the car to warm up before boosting. mine used to do it all the time and it pissed me off. the only way to get around it is by bypassing the solenoid with a manual/electronic boost controller.
once again: problem solved.
plus i cant imagine the worth it:price ratio for a new solenoid, which is most likely not going to fix the issue.
https://www.sau.com.au/forums/topic/406537-m35-boost-issue/#findComment-6478798
No, don't know the cost. BUT either take up Scotts offer or get an aftermarker boost controller. Even with the wastgate actuator spring Mod the car felt stronger on initial boost when I used the Greddy Profec B boost controller. It bypasses the factory one so no more problem.
Cheers
Andy
https://www.sau.com.au/forums/topic/406537-m35-boost-issue/#findComment-6479728
yeah i thought of keeping it though it's one less thing i gotta worry about second guessing me bleed valve :)
Just keep it in the glove box or boot hiding spaces, if the problem ever occurs plug it in and drive home?
https://www.sau.com.au/forums/topic/406537-m35-boost-issue/#findComment-6481080
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
