Can anyone recommend a place in sydney to install alarm? Probably will look at vipers or this one
Best to PM Chris Rogers mate, he's in Brisbane but i'm sure he will know someone in Sydney. Considering i'm in Mackay and he hooked me up with someone local :P
still deciding if its worth the effort myself. external keypad is definitely asking for trouble. a can of freeze it would do nicely on it and render it prettymuch useless. bit of dirt across the pad too many times would reveal the sequence into it.
as for ADR - are you kidding??
Definitely appears impressive but I'm with Chris on this one. Anything which leaves the control system vulnerable to being messed with by anyone other than you is not a secure thing. It's not like you're using an RFID swipe card or something. I wouldn't waste my time with it.
I've got a Viper 5904 on its way from the US along with the XpressKit DBALL interface, tilt and perimeter sensors. I used to have a Clifford Avantguard G4 in my old Maxima with the remote start and that was a fantastic unit but I decided against installing that in my V36 even though the Viper doesn't have the anti-carjacking feature. It was more about simplicity of the installation which an old legacy unit like the Clifford didn't seem appropriate. I don't care much for the SmartStart thing with the iPhone though. A remote key fob is more than enough for me.
And yes, forget about ADRs. Just use the remote start wisely (i.e. Don't start it in front of the police!).
Been doing a bit of reading on this and you can choose not to have the keypad hooked up at all or place it in a more conspicuous location... say glove compartment. Am really curious about this bit of kit... may go ahead with it... maybe... hmm...
Spoke to Chris a little earlier. Fk this idea. Too much can go wrong.
It's kind of like when people buy flashy phones but can't make calls because of no signal or whatever.
This alarm looks flashy and awesome but security really isn't there. So no thank you.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
