Basically parting out most of my silvia track car and going in a new direction. This set up made a reliable 255kw atw all day every day, never had an engine problem. Engine has travelled very few kms since i pulled it from a front cut in 2009 maybe 6 - 10 events a year. Has been tuned by chea at powertune and jim at croydon racing developments and both said that it tuned like a fresh motor. Was tuned for response opposed to top end power. Slightly negotiable on items if sold as a whole package. other wise not negotiable.
ring or sms me on 0418772525, dont check the forums much
93 redtop sr20det 85,000 kms
-copy greddy inlet manifold
-BC 264 in & ex cams
-BC valve springs
-BC titanium retainers
-Moroso aluminium sump
-nismo thermostat
-speedflow dash fittings fitted to rocker covers
-alloy pulley kit
-Greddy oil cap
-oil relocator block
$1500
Haltech e11v2 with patch loom to suit red top sr20det
-currently has tune to suit this package on it
-air temp sensor
-3 bar map sensor
$1100
Splitfire coil packs to suit redtop sr20
$350
Sard fuel rail with sard green 800cc injectors
$500
Motorsport connections catch can setup to suit
-speedflow fittings
-push on hose and heat shielding
-drains to sump
$180
Trust Td06 20g kit
-td0620g turbo
-genuine braced greddy high mount manifold
-genuine trust 50mm external gate and screamer
-oil lines to suit
-braided vacuum lines
-best turbo for sr20s bar none
$2000
OS Giken twin plate clutch r2cd
-awesome clutch
-good condition
-never slipped
-never had any problems
$1500
Z32 gearbox conversion
-1 manual z32 gearbox
-Thicker sr20 auto bell housing cut and shut by Stewart Wilkins motorsports
-gearbox mount to suit s13
-shifter mount shortened so it pops up in the standard position
-gearbox is a bit notchy into third, apparently pretty common with z32s
-$900
Can do all of the above items in a package deal for $7600
standard z32 gearbox
-had as spare and never used it
-been sitting in my shed for 2 years
-never used but selects gears by hand fine
$500
Gtir quad throttle bodies
-came off a wreck with 28000km's
-convert your sr to quads
$450
Standard sr intake manifold
-combine with above manifold to convert runners
$50
Rb25 NEO motor
-no manifolds
-comes with power steering pump
-alternator
-was going to use in a project but haven’t ended up using it
-came out of a rear ended low km r34
$1000
Blitz alloy GTR individual throttle body adapter plates to suit rb25
-convert GTR itb's to your rb25
-extremely rare
$550
GTR individual throttles
-everything from head to plenum
-great condition
-combine with plates above for awesome response on your rb25
$500
Rb25 NEO gearbox
-low kms
-comes with shifter
-best rb box available
$1350
full 7 pointsafetyl 21 bolt in cage to suit sunroof s13
-comes with bolts and plates
-side intrusion bars
$670
3 greddy gauges
- water temp
- boost
-exhaust temp
$250
3 sabre gauges
-fuel pressure
-oil pressure
-oil temp
$100
hey mate, i am pretty sure they are sold. Waiting to confirm this saturday. I havent fitted them before.They dont make these anymore and i have only ever seen one other set for sale in Australia........ there the business and they are also on ebay at the moemnt
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
