1989 bnr32 the car is in great original condition comes with genuine factory gtr key and nissan spare key (both with matching serial numbers) full documented service history from nissan japan/nissan aust.Ad08 tyres all round redline and amsoil used 83000kms a true collectors car 22000 ono
Edited by reni
https://www.sau.com.au/forums/topic/406937-factory-gtr32/
I just noticed on Carpoint its down to $19,900.00.......
http://www.carpoint.com.au/all-cars/private/details.aspx?R=13189160&YearFromShort=1633&__Qpb=1&keywords=&Cr=10&__Ns=pCar_PriceSort_Decimal|0||pCar_RankSort_Int32|1||pCar_Make_String|0||pCar_Model_String|0&SearchAction=N&YearToShort=1668&__N=1216 1247 1282 4294963593 4294963846 1622 4294933125 1633 1668&silo=1011&seot=1&__Nne=15&__No=15&trecs=52&__sid=1391C0E143CC
I'm stunned it hasn't sold. Has anyone seen it in real life? Are there any issues? PM me if you know anything.
If I had a spare $20K I'd buy and park it. These things are near impossible to find in stock condition.
It has taken me 6 months to get mine to this condition and it owes me a lot more than the current asking price.
Cheers,
Bob.
https://www.sau.com.au/forums/topic/406937-factory-gtr32/#findComment-6505376
  • 3 weeks later...
  • 3 weeks later...
hey mate, The car looks very clean. Is there any rust?
Also thoughs fog lights near the front bar, they are aftermarket correct? Are they easily removed with no
damage, screw holes etc.
cheers ben
https://www.sau.com.au/forums/topic/406937-factory-gtr32/#findComment-6557737
  • 1 month later...
herb, have a look in car sales, was on there about 3 wks ago.
This 32 gtr needs a good home, its perfectly original.
The car is still on Carpoint and I'm buggered if I know why.
http://www.carpoint....id=1391C0E143CC
When I was looking around this time last year and bought my JDM in February, there was nothing but junk around.
I've spent a sh1tload on my car which I've finally finished restoring but it owes me bucket loads more than this car.
The longer it's on there, the more tarnished it gets. It's a shame because from what I've heard it's a good car.
Bob.
https://www.sau.com.au/forums/topic/406937-factory-gtr32/#findComment-6627921
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
