Hi all
Ive got both options available at the mo as both are available in full kit form locally
however the turbo kit has no ecu,so what do you suggest for the piggyback?
Or should i go the blower which has the a/m ecu? Decisions!?!
https://www.sau.com.au/forums/topic/407102-supercharged-vs-turbocharged/
  • Replies 80
what is your power goal?
Uprev for the ECU will work as long as you keep the AFM, even if upgraded AFM and will be most probably the cheapest/easiest solution.
Are you doing work yourself or handing it over to a workshop? Budget? Location?
i have a mate who has done the supercharger kit on a vq35de and has worked on lots of turbo cars before, as hes a mechanic
im in perth and no-one really does v35s over here. im a boilermaker so exhaust fab is no issue.no set budget as such.
leaning toward turbo kit cos its garret with hks pipes intercooler etc. any feedback much appreciated, might buy it tomorrow.
saw the kit, was mint and the price was too good not to buy it
so i did :yes:
brand new garret with hks gear even chucked in the auto upgrade for free
stoked- install next week 350hp here i come
Nice, got any pics? How are you tuning it?
the kit is an HKS special turbo system kit gt3037 56t
i can get a perfect power smt8 ecu for nothing, is this an anyway decent unit? or should i buy something else?
tuning at a mates workshop, its not what you know........... :rolleyes:
it has instruction manual in japanese but i know someone.... also the kit is made for a vq35de so shouldnt be a big issue
my car has a nismo a/m exhast and i know a guy who wants to swap mine for his coz he took a turbo kit off his putting it back stock to sell.
i know a guy with big injectors for sale if required and i have nismo irridium plugs in it looking into afm now
You will probably need colder plugs anyway. Do you have the number of the ones you put in?
I can get Bosch 1000's that drop straight in and idle perfectly for around $600 new, so don't pay too much for second hand ones, in fact I would be buying new anyway.
Your mate is going to be pissed with you, it isn't an easy kit to fit. Probably easier to pull the engine. Any idea what boost you plan to run? Has the tuner worked on VQ's before?
You might know a lot of people- But I installed that kit, got the tuning software, and made it run. On a car it was never designed for. So I know exactly what you have to change.
All I hope is that the people you know have some decent knowledge about VQ35des and turbos. Otherwise it'll never make it off the dyno. I suggest you research some more.
yeah hes done a vq with a vortek blower kit install in a 350z. My turbo guru has 15yrs exp with snails and charges in cartons of beer :no:
If he doesnt know it its not worth knowing so im in good hands.Im planning on 7psi at this stage cos thats what the previous guy ran on his.
Any thoughts on the perfect power smt8?
cheers
As PN-Mad said ther are many better options,
Haltech Platnium Pro (new one swaps the ecu completely), old one plugs into it <---- One of these prob the best option ~$2600 new, $1400 2nd hand from usa
Utec with MAP sensor <--- piggy back but also acts like a standalone after certain RPM <---- Pre Osiris was the best affordable EMS, $1000new (no longer made), $450/500 2nd hand from usa
Uprev Osiris <--- Cable and software to flash your stock ECU, good for a upto certain HP, but you need upgraded MAF $600 new, 2nd hand varies $400ish - there are more $ types like tuning model or something
The Haltech and Utec both run MAP sensors which you use instead of the MAF sensor.
Haltech is a must for another over 500HP id say
Utec is good if you like the extra like external map selector, boost controller etc and good for up to 500HP, maybe more
Osiris i dont know what HP this is good for...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
