For sale is a non-running early 1997, series II BCNR33 GT-R V-Spec.
Perfect for a mechanic or for somebody willing to start a new project.
Engine suffered a failure in the #1 cylinder, causing block damage and also #1 turbo damage - I am not sure what it will need to get it running, but it would have to be a full rebuilt or a 2nd hand motor.
I bought this car 18 months ago when it had 102,000. Took great care of it, but unfortunately .........shit happens.
Body is perfect - this car's chassis is in a great condition, just needs a motor :whistling:
Chassis has travelled 118,000kms.
Wheels are standard 17x9 +30 with 3,000km old Dunlop Direzza's Z1 Star Spec tyres.
Stereo is Pioneer MVH8300BT.
Speakers are Pioneers 6.5" TS-A1604C splits
Interior is perfect. Comes with R34 V-Spec II pedals.
Gearbox is in a perfect condition - recently serviced with Motul oils.
Diff has also been serviced with Motul oils. Fluids in transfer case have also been changed.
Brakes are standard Brembo's with Ferodo DS2500 pads that have recently been serviced with RBF 600 fluids.
I'd love to be able to spend time and money and get this great car running again but I'm just not in the position to do that so here it is.
Price: $13,000.
https://www.sau.com.au/forums/topic/407182-1997-r33-gt-r-v-spec-non-running/
Ok thanks.
Problem is I live in Mackay north QLD, I'd have to get it trucked.
I'll see what my options are and let you know. Very interested though.
Edited by The Mafia
Lot of interest, lot of interest, and people have been asking me for more pics - so here is one of the interior, one of the broken engine (with piping and the radiator removed) and one of the underside.
Please understand that car is being sold completely stock.
Car back on sale - buyer unable to sort finances....
If you are after immaculate, stock BCNR33 that needs an engine then this is the one for you - price $12,500
Do you have auction papers from Japan specifying vehicle grade etc?
Interested but has this had the left front quarter panel replaced or repainted? Only reason I ask is because colour is different in this pic
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=399893
dont know if we can or should be asking that....
But one thing I am interested in knowing....what is the approximate cost of the options the new buyer for such a car has, in other words;
a. cost of finding a used RB26 sitting around, and swapping this in - factoring in all costs including money made from the dead block and
b. cost of simply re-building the RB26 already in it - from the ground up
Am I right in guessing about $6K the first option, and $10K the second option?
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
