4 of these wheels, suit skyline. may fit others.
17x8 approx +26 225 fronts with legal good bridgestone potenza RE01 adrenalin tyres.
17x9 approx +28 235 rear with dunlop tyres on indicators.
Unknown brand
Fresh paint! One has small flake where centre cap goes
500 firm come get em Ararat, VIC 3377 0423 393 521 message me I cant take calls. not interested in postage.
https://www.sau.com.au/forums/topic/407265-17-wheels/
  • 4 weeks later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
