great post Markos... it's kind of like golf, you against the course... yeah I like to play golf too lol
well I've been bitten by the bug... no more circuit stuff for a while, I'm going 5 x 5 for the next 6 weeks or so... was a little annoyed I didn't find the limit last Sun so I have some goals in mind... maybe a bit optimistic but hey you have to give it a go... I want a 200kg squat (+40kg), 130kg bench (+20kg) and 250kg deadlift (+60kg)
maybe I should make a build thread to keep me honest...
ps. is a narrow squat (oly style) a disadvantage? I'm not comfortable squatting wide
those gains in 6 weeks might be a little difficult but sounds like you left maybe 10-20kg total in the tank.
I don't know if I'd call it a disadvantage... it makes for stronger, larger quads.
A wider stance tends to use hamstrings and arse/hips alot more than narrow.
a narrow squatter uses quads as the major power.
so if you learn to squat wider, you use quads and hip drive making for a more POWERFUL lift. and probably heavier weight.
but like anything it takes some getting used to and expect to start with half the weight and struggle until all those supporting muscles catch up.
Also requires some flexibility in the inner thighs and so forth.
you'll find that your knees will probably cave in when coming up from a squat when squatting wide with a challenging wight for a while.
If you want to lift the most weight, then you'll probably want to use the best leverages you can.
sumo stance deadlift means the bar moves a lot less than conventional, but it is not easy to lift more weight... it becomes a hip exercise more so than legs and back.
Bench, arch or no arch, wide grip or closer...
lots of ways to lift more weight.. just depends what you are comfortable with.
If you want the opinion of someone who is injured more than they would like... Stick to what you are comfortable with and don't try chasing numbers by adjusting the way you do something cause someone else is.
Markos hasn't mentioned it but I will. He has put together a Progressive Program for strength training that many of us utilize. It would be worth your $20 (or possibly lower for an iPhone app if that is ready yet).
thanks for the feedback... those numbers are just a goal, don't think I'll achieve them in 6 weeks but I'll certainly give it a shot
sounds great Markos, I'd love another go with the good gear! That program could be really helpful, how do I go about it... email you?
Markos WTF have you done to me... I had a dream about squatting the other night... I have a heap of work to do but instead have been reading and daydreaming about lifting (who daydreams about lifting weights...seriously!?)... I have a persistant NEED to get into the gym... who would've thought this shit is addictive... you should probably put a warning on those newsletters lol
ps. my legs hate you
I was a little bit this way when I discovered just how good it felt to squat 1.5x BW for repssssss
actually having a program has given me some much needed focus... I always liked just lifting but its awakened my competitive side... my competitive side is usually buried deep as he's a bit of a monster and doesn't play well with others... now he's awake and wants PB's... I must feed him
There is a whole community of us mate.
you'll end up there soon enough.
"one of us!! one of us!!"
Due to a re-occuring back injury I had been thinking of giving it up.
Got home today to find a certificate for my National Record.
by default really as there was no-one else as old as me in the same weight division... but still, seeing it has ignited fire again.
It was 4 months between injuries... I'm going to make a proper effort at sorting it out this time so lets see how long I can go before half throwing the towel in again.
hahaha glad I'm not the only weirdo then;)
back injuries are the worst, hard to train around... I guess as you get older you have to train smarter... I'm definitely not as indestructible as I once was and I can't get away with a eating crap anymore
that's the beauty of strength sports though... you might get slower as you age but you still can get stronger... as long as you can remain healthy
good luck with it, don't give up just try a different approach
Tolga dont sell yourself short on that record, you can only beat who shows up. Thats your record to break now, at States next year.
Nick, you have been bitten by the Iron Bug. Youre welcome.
Having a program set out for you is a great motivator, you cant go soft cock in the gym if youre having a bad day, its already written up for you.
How good does it feel when you get through another week.
Its why I made it only $20, the more people I can get training correctly, the better our sport/hobbie will become
fck that was brutal today... squats week 2 (180kg program), followed by bench week 3 (120kg program)... I'm struggling with the squats, I don't have a spotter or any pins/bars set up so when I start fatiguing I break down mentally and slowly squat higher and higher... so I added another set at the end at 100kg and made sure I was ATG on every one, pausing at the bottom... squats are all in the head!
my lower back/glutes were still fckd from deadlifts on Tue but I soldiered on... just have to get used to squatting and deadlifting twice a week... and maybe have a can of harden the fck up lol
I wanted to do some heavy bent over rows, only got through 2 sets before my butt muscles cried enough so I just did some other assistance stuff
the bench is going much easier... I'm benching 3 times a week as I never used to do much bench so feel like I have a long way to go... no spotter but hasn't been an issue so far... I guess it's a good motivator to get the weight off your chest... either lift it or lay there whimpering lol
Deadlifts are going well too, I'm doing the 220kg program... the garbage bars are ripping my hands to pieces with the super sharp knurling but I figure it will stop hurting after a while... I still can't get over how much nicer the bar at PTC was to hold (and chalk helped)... I'm considering buying my own bar and keeping it in the office
I may need to actually use a protein supp now... I've never supplemented but can see how taxing a program like this is going to be... milk and eggs might not be enough anymore?
Hey chief.
Normally PPP is done 1 lift per session.. lol
Monday squat and accessories
Wednesday Bench and accessories
Friday Dead and accessories
How are you programming it?
re: hands - got any chalk? if not get some. if gym doesn't allow it, you can get a chalk/alcho/gel stuff from outdoors type stores where they sell rock climbing gear. that stuff doesn't leave a mess.
Those bars at PTC cost more than a years membership to most commercial gyms.
edit - benching by yourself - if you don't have pins to drop it on to, make sure you DON'T put the collars on the end of the bar. so if you get pinned, you just tilt one side down, it dumps the plates and be ready for when it flings over to the other side.. lol
Edited by TTT
oops! lol
Squat + Bench + accessories - Tue
Deadlift + Bench + accessories - Thu
Squat + Bench + accessories - Sat
I find the bench press a lot less taxing than the SQ or DL so have been doing it every session... I might swap it out for overhead press on one of the days... although I've been doing OHP as assistance most sessions as well...
I might see how long I last doing it this way, if I hit a brick wall I'll dial it back... really want to squat 2 x a week for a while as I reckon it has the best carryover in terms of athletic performance... and I'm still clinging onto the fantasy that I might be able to dunk one day lol
I never put collars on
Edit: sorry I'm only DL once a week, not twice as I mentioned in previous post... although I do use powercleans and rack pulls as assistance
Edited by NickR33
Rowdy, somecsstudent on here, did PPP, all 3 lifts, 3 x week. He got to a 200kg squat, 130kg bench and 230kg deadlift
He finally hit the wall, but those lifts at 85kg are pretty good
The Eleiko bar we used for squats and bench costs $2000, the Texas deadlift bar costs around $800
I'll keep at it then, see how I hold up
hmmm wonder how I'm going to get a DL bar purchase past the wife... better than spending money on the car honey... all in the name of good health!
Actually she is keen to come down and have a look at your gym since I told her how many strong girls you have down there... she's greek so you guys probably know each other lol ;)
I actually know very, very few greeks, none outside my gym
It would be great to have her come see.
The stronger girls train at 11am 4 times a week
Heavy deads tomorrow morning at 11, last heavy deadlift session before Worlds
Nina and Amanda should pull 140kg, Sussy and Vicky 130kg
yeah was just playing on the stereotype... she was very happy to take my last name when we got married, her maiden name took far too long to write and nobody ever spelt it correctly
very impressive lifts, I know lots of blokes who couldn't pull that... strong women are awesome!... Kal deadlifted 6 x 55kg the other night which was pretty good for her (she is 50kg)... she is okay deadlifting but her squat needs work... been trying to get her to squat deeper as she is still way too high... just a confidence thing I think
Just joined the pro raw forums... checking out people's logs, very helpful
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
