lol
probably at the stage where I need to shave it... get some Markos style... might even get some tatts/piercings! ;)
does stop me from getting hassled driving the R though... the boys in blue must think I'm a bit older and therefore more responsible... ha!
Markos my folks were very impressed with ProRaw4... they only came for a bit, watched the bench press then went home and watched the rest on the live feed
so anyway, day 3 of 'dieting'... verdict: its massively gay
did a lighter, high rep, dumbbell pressing session last night... including lots of shoulder work... low rest times and lots of drop sets... my god is it boring!
hardly raised a sweat so went and did some high rep squats to finish... last set was 100kg x 20... fark
The GPC National Push Pull is on Sunday the 18th. Its run on the same day in each state.
Victoria - PTC Frankston
Queensland - PTC Brisbane
Western Australia - PTC Perth
NSW - PTC Sydney
ACT - Elite Physique
NT - Power Pit gym
I have one SA competitor fly in to compete at Vic
Anyone interested in watching is welcome, entry is free
Thats pretty cool, so no benching at the moment?
Just cleans/snatches/squats/front squats/overheads
Pretty much spot on.
Weightlifting is the only thing I'm really enjoying at the moment so I'll try to capitalise on that while i can.
We have a good gym at work, i'll still bench there and do a few other things, but at least i can really work on the basics
at home.
Once i c&j over 140 i might go back to powerlifting
the start of my new setup at home.
I have 250kg to start with, will have to add to that hopefully.
Very cool setup!
I would love to do some weightlifting but need some coaching first (and somewhere to do it)... I power clean/push press often but never even attempted a proper jerk or snatch... I can't even overhead squat properly as my mobility is poor
170kg bench at > 90kg! ... man I have some work to do :(
sounds good
I've resigned my full time position and am going into business for myself so should be able to get to the PTC during the week next year... Hopefully I can split my training so it's twice a week down there and twice up here
I know much more progress could be made training at PTC
What do the numbers in the gloss table represent?
Glossbrenner is a formula calculator
You punch in your bodyweight, weight lifted and it spits out a score. It also allows for age correction for over 40's and gender
Here is a link on my site, its easy to work with
http://www.ptcfrankston.com/glossbrennercalculator.html
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
