I find I can squat and bench multiple times a week and still get quality work in on other movements
but deadlifting has to be planned out a bit because of the lower back fatigue... once the lower back and grip is gone I find it hard to do much else and need a full 48 hours to recover... otherwise my workout is compromised... lots of foam rolling on the lower back helps
I used to give equal time to squatting and deadlifting but now I'm focussing more on squatting and just deadlifting once a week... I find a stronger squat helps the DL, but it doesn't work the other way round
Catherine Pascoe - 59.8kg - na/55/90 - na
Troy Hewlit - 87.4kg - 110/77.5/152.5 - 340kg
Kris Baldry - 97.2kg - 170/90/190 - 450kg
Armando Miotti - 90.7kg - 172.5/110/180 - 462.5kg
Hoan Dang - 89.5kg - 162.5/125/215 - 502.5kg
Stelian Tchapkanski - 95kg - 150/145/210 - 505kg
First time for a while where we had only novices, no lifter was a member of a fed
No novice comps in February or March due to the ProRawQualifier and Vic States
April before our next novice comp
Edited by markos
^^ you don't have runners?
I've got a $20 pair of K-mart specials lol - I don't ever really use them. The closest I get to an activity that warrants runners would be riding my bike, which I wear my skate shoes :P
I do actually have a pair of Vans Authentics that I've squatted in before and they did quite well, though personally I prefer barefoot anyway.
i'm not talking about just lifting, I wear weightlifting shoes for most most of my lifting.
I didn't realise he didn't run, sprint, do circuits, play some sport, or do anything apart from lifting weights.
I sprint barefoot on a grass track :P I ride a downhill bike which is horrifically inefficient when not going down a hill....aaaaaaand I'm considering taking up soccer again this year, so I'll obviously need to buy boots for that. If I have time for it at least.
I just don't have time and couldn't be f**ked doing anything other than the above on top of lifting. Don't see the point.
I don't do any of those.
Drive to work in Business attire.
once home I walk the dogs
then lift
then repeat.
I do have sneakers though... for the walking of said dogs
Edited by TTT
^ I used to think the same, now I look over to my shoe rack and see work boots, black business shoes, and trendy fasion shoes not suitable for anything practical. Oh how the times change, back in the day all I used to have was runners, would wear them everywhere.
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
