I find I can squat and bench multiple times a week and still get quality work in on other movements
but deadlifting has to be planned out a bit because of the lower back fatigue... once the lower back and grip is gone I find it hard to do much else and need a full 48 hours to recover... otherwise my workout is compromised... lots of foam rolling on the lower back helps
I used to give equal time to squatting and deadlifting but now I'm focussing more on squatting and just deadlifting once a week... I find a stronger squat helps the DL, but it doesn't work the other way round
Catherine Pascoe - 59.8kg - na/55/90 - na
Troy Hewlit - 87.4kg - 110/77.5/152.5 - 340kg
Kris Baldry - 97.2kg - 170/90/190 - 450kg
Armando Miotti - 90.7kg - 172.5/110/180 - 462.5kg
Hoan Dang - 89.5kg - 162.5/125/215 - 502.5kg
Stelian Tchapkanski - 95kg - 150/145/210 - 505kg
First time for a while where we had only novices, no lifter was a member of a fed
No novice comps in February or March due to the ProRawQualifier and Vic States
April before our next novice comp
Edited by markos
^^ you don't have runners?
I've got a $20 pair of K-mart specials lol - I don't ever really use them. The closest I get to an activity that warrants runners would be riding my bike, which I wear my skate shoes :P
I do actually have a pair of Vans Authentics that I've squatted in before and they did quite well, though personally I prefer barefoot anyway.
i'm not talking about just lifting, I wear weightlifting shoes for most most of my lifting.
I didn't realise he didn't run, sprint, do circuits, play some sport, or do anything apart from lifting weights.
I sprint barefoot on a grass track :P I ride a downhill bike which is horrifically inefficient when not going down a hill....aaaaaaand I'm considering taking up soccer again this year, so I'll obviously need to buy boots for that. If I have time for it at least.
I just don't have time and couldn't be f**ked doing anything other than the above on top of lifting. Don't see the point.
I don't do any of those.
Drive to work in Business attire.
once home I walk the dogs
then lift
then repeat.
I do have sneakers though... for the walking of said dogs
Edited by TTT
^ I used to think the same, now I look over to my shoe rack and see work boots, black business shoes, and trendy fasion shoes not suitable for anything practical. Oh how the times change, back in the day all I used to have was runners, would wear them everywhere.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
