yep it starts gently but gets painful quickly
if training for strength you want to be fully recovered for each of your heaviest sets... it can be 5 min or longer... you want to approach the set with 100% effort and focus... it's a bit of a balance between recovering fully and getting cold (which isn't much of an issue at the moment)
cheers
last week was easy, I felt like I could go much heaver... this week was just 5kg more but was super tough... I have burst a blood vessel in my eye, look like a stoner lol... need more practice in the wraps
I also did 115kg x 3 on the bench press yesterday which is a PR... not very impressive I know but I'm making progress which is nice
poor Martin
Righto, I'll try out 3 mins or so and see how I go.
I tested out my 1rm for bench yesterday without a spotter (but in my cage with safety's) and I got 105kg.
So should I do the 115kg program or 120kg?
Which one do you think is achievable in 3 months? I played it safe and only went 10kg up on bench. if I gain 40kg on bench in 12 months, I'll be exstatic.
I did 120kg 1RM on the bench and tried the 140kg PPP, by week 4 it was too much. I was giving myself 3 minutes between sets which probably wasn;t enough but even then the weight would have been a struggle.
I think 10kg is safe, 15kg is hard and 20kg is really pushing it, if not too much.
Thats right, try it and see as everyone is different.
I mentioned on my ProRawForum how Zoran started on the 180kg deadlift program first week of September. He told me it was his old PB, he pulled a very hard 160kg in front of me, so we started on 180kg.
Before I got back from Worlds late September, his assistance exercises included 220kg pulls from a deficit for reps. In late November he deadlifted 280kg at the National Deadlift comp, on the weekend he pulled 290kg
This guy doesnt even drink protein shakes, has a 130kg improve in 5 months, he may be 2-3kg heavier
my mate swears by that craze stuff... but he gets out lifted by girls so I never bothered with it
I'm glued to the couch watching basketball today... just those couple of tough grind squats yesterday have broken me
might just lay down on that comfy new bench tomorrow
This just makes me think what the hell was he doing before!
So many gains
if only... Sigh.....
I'm trying + 20/10/20
Edited by jangles
Who would have it any other way! All star weekend this weekend as well.
I agree that 15kg is a pretty optimistic jump for 11weeks on any exercise, but hopefully i can get it done. Is it a good idea to change up the reps of the assistance exercises each week ie 5 reps one week and then 12 another week and 8 the next etc or should i stick with one?
Zoran came from a boxing back ground
Made a decision to compete in powerlifting and joined our gym
Started at 140/120/160
Now 235/145/290
He is 23 and been training in gyms like others do, his lifts were okay in a regular gym
I hear Craze is off the market now
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
