yep it starts gently but gets painful quickly
if training for strength you want to be fully recovered for each of your heaviest sets... it can be 5 min or longer... you want to approach the set with 100% effort and focus... it's a bit of a balance between recovering fully and getting cold (which isn't much of an issue at the moment)
cheers
last week was easy, I felt like I could go much heaver... this week was just 5kg more but was super tough... I have burst a blood vessel in my eye, look like a stoner lol... need more practice in the wraps
I also did 115kg x 3 on the bench press yesterday which is a PR... not very impressive I know but I'm making progress which is nice
poor Martin
Righto, I'll try out 3 mins or so and see how I go.
I tested out my 1rm for bench yesterday without a spotter (but in my cage with safety's) and I got 105kg.
So should I do the 115kg program or 120kg?
Which one do you think is achievable in 3 months? I played it safe and only went 10kg up on bench. if I gain 40kg on bench in 12 months, I'll be exstatic.
I did 120kg 1RM on the bench and tried the 140kg PPP, by week 4 it was too much. I was giving myself 3 minutes between sets which probably wasn;t enough but even then the weight would have been a struggle.
I think 10kg is safe, 15kg is hard and 20kg is really pushing it, if not too much.
Thats right, try it and see as everyone is different.
I mentioned on my ProRawForum how Zoran started on the 180kg deadlift program first week of September. He told me it was his old PB, he pulled a very hard 160kg in front of me, so we started on 180kg.
Before I got back from Worlds late September, his assistance exercises included 220kg pulls from a deficit for reps. In late November he deadlifted 280kg at the National Deadlift comp, on the weekend he pulled 290kg
This guy doesnt even drink protein shakes, has a 130kg improve in 5 months, he may be 2-3kg heavier
my mate swears by that craze stuff... but he gets out lifted by girls so I never bothered with it
I'm glued to the couch watching basketball today... just those couple of tough grind squats yesterday have broken me
might just lay down on that comfy new bench tomorrow
This just makes me think what the hell was he doing before!
So many gains
if only... Sigh.....
I'm trying + 20/10/20
Edited by jangles
Who would have it any other way! All star weekend this weekend as well.
I agree that 15kg is a pretty optimistic jump for 11weeks on any exercise, but hopefully i can get it done. Is it a good idea to change up the reps of the assistance exercises each week ie 5 reps one week and then 12 another week and 8 the next etc or should i stick with one?
Zoran came from a boxing back ground
Made a decision to compete in powerlifting and joined our gym
Started at 140/120/160
Now 235/145/290
He is 23 and been training in gyms like others do, his lifts were okay in a regular gym
I hear Craze is off the market now
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
