2013 GPC Vic States
WOMEN
48kg class
1. Melissa Knight - 47.7kg - 85/47.5/110 - 242.5kg
60kg class
1. Rebecca Gleich - 57.8kg - 120/67.5/150 - 337.5kg
2. Sussy Kollen - 57.8kg -110/72.5/120 - 302.5kg
3. Vicki Jewson - 57.7kg - 90/57.5/130 - 277.5kg
67.5kg class
1. Heidi Stewart - 60.6kg - 110/70/150 - 330kg
2. Megan Reily - 65.4kg - 100/BMB/130 - BMB
75kg class
1. Jay Jama - 71.0kg - 60/30/95 - 185kg
82.5kg class
1. Emma Bortolotto - 81.9kg - 130/67.5/140 - 337.5kg
MEN
56kg class
1. Marlon John - 54.8kg - 115/80/120 - 315kg
67.5kg class
1. Jesse Markopoulos - 66.8kg - 160/100/190 - 450kg
2. Luke Bender - 66.0kg - 110/100/200 - 410kg
75kg class
1. Emad Nayef - 74.7kg - 235/115/255 - 605kg
2. Robbie Tissera - 73.1kg - 227.5/120/220 - 567.5kg
3. Ivan Ho - 70.7kg - 165/120/170 - 455kg
4. Dim Papaconstantinou - 70.5kg - 145/100/185 - 430kg
5. Daniel Distefano -69.5kg - 125/100/160 - 385kg
82.5kg class
1. Martin Nguyen - 80.9kg - 252.5/157.5/275 - 685kg
2. Eddie Dargham - 81.2kg - 185/105/250 - 540kg
3.Chris Van Gunst - 78.3kg - 150/125/235 - 510kg
4. Jordan Zollo - 82.4kg - 150/130/200 - 480kg
5. Sam Boyce - 81.3kg - 140/112.5/185 - 437.5kg
6. Dimitri Jayaratne - 76.7kg - 135/57.5/175 - 367.5kg
7. Adrian Zwaan - 81.9kg - 95/80/160 - 335kg
8. Krit Barnett - 82.0kg - 130/105/65 - 300kg
90kg class
1. Max Markopoulos - 89.8kg - 260/155/250 - 665kg
2. Adam Lam - 89.3kg - 240/140/260 - 640kg
3. Erros Chiodo - 88.0kg - 215/125/275 - 615kg
4. Nick Edlin - 88.8kg - 210/132.5/240 - 582.5kg
5. Keng Tan - 89.7kg - 215/142.5/220 - 577.5kg
6. Conor Zyskowski - 87.0kg - 230/110/230 - 570kg
7. Stelian Tchapkanski - 89.9kg - 180/150/215 - 545kg
8. Ethan Perera - 87.3kg - 130/80/150 - 360kg
100kg class
1. James Jenai - 94.5kg - 245/175/250 - 670kg (180kg 4th BP)
2. James Visciglio - 97.9kg - 195/135/272.5 - 602.5kg
3. Nick Haralambopoulos - 97.6kg - 185/120/250 - 555kg
4. Wayne Kollen - 99.8kg - 200/130/225 - 555kg
5. Josh Rayson - 96.9kg - 185/120/220 - 525kg
6. Kris Baldry - 99.7kg - 200/105/205/510kg
7. Ronnie Chau - 94.6kg - 170/100/242.5 - 512.5kg
8. Ross Katsambis - 97.7kg - 170/105/215 - 490kg
9. Jake Clinch - 95.1kg - 70/140/75 - 285kg
10 . John Nichols - 93.6kg - 80/75/75 - 230kg
11. Aaron Scarborough - 96.6kg - 80/80/65 - 225kg
110kg class
1. Daniel America - 104.3kg - 230/140/260 - 625kg
2. Nick Rankin - 102.3kg - 200/140/240 - 580kg
3. Will Grainger - 105.8kg - 215/125/230 - 570kg
4. Duke Catherine - 108.2kg - 135/105/190 - 430kg
5. Jeremy Buchanek - 101.1kg - 80/75/75 - 230kg
6. Gregg Gordon - 108.5kg - 80/75/75 - 230kg
125kg class
1. Zoran Jankovski - 114.3kg - 250/145/292.5 - 687.5kg
2. Joe Zollo - 119.1kg - 220/120/240 - 580kg
3. Alan Kissick - 116.8kg - 165/105/215 - 485kg
4. James Thompson - 116.0kg - 110/85/175 - 370kg
140kg class
1. Spiros Markopoulos - 128.0kg - 70/152.5/75 - 297.5kg
SHW
1. Jack Pollard - 148.1kg - 280/170/280 - 730kg
EQUIPPED MEN
100kg class
1. Barry Murray - 97.1kg - 200/160/200 - 560kg
2. Brendan Hains - 95.1kg - 270/BMB/260 - BMB
BENCH ONLY
WOMEN
82.5kg class Equipped
1. Emma Bortolotto - 81.9kg - 90kg
MEN
100kg class
1. Laird Ross - 93.9kg - 180kg
2. Alen Pezerovic - 93.9kg - 130kg
Stoked, got my 102.5kg x3 bench out last night!!!
Week 7 here I come.
Tried doing some paused reps on 90kg and wow that makes it about fifty times harder. No way would I get 102.5kg out without utilizing the stretch-shorten cycle.
the pause does get easier the more you practice it... just have to concentrate on keeping tension
That's what I've found when I've dicked around with the pause. You habitually allow too many muscles to relax when you pause, as your mind wants to use it as a chance to rest....when in reality you want the exact opposite! Keep those muscles tensioned haha
SS as in starting strength?
SS is 3 sets of 5 reps for working sets for sq, bench, OH press
Deads is 1 set of 5 reps
Power cleans are 5 sets of 3 reps.
There are no 5 working sets apart from the power cleans.
and warms ups is a personal thing... if I only did 2 warm up sets and got straight in to the work sets, I'd break more frequently than I do now.
SS as in starting strength by Mehdi
think the program has changed slightly but I could very well be wrong.
Workout A:
Squat
Bench
Barbell Rows (I don't do these, I do seated cable. Reason is I get heaps of pain in my wrist joints from it)
Workout B:
Squat
Overhead Press
Deadlifts
Straight from his book that he sends to everyone:
"You'll do 5 sets of 5 reps (5x5) with the same weight on every exercise after you've done
your warm-up sets. There's 1 exception, Deadlifts, where you'll only do 1 set of 5. Here's
why: 5x5 or even 3x5 Deadlifts would mess with your recovery and cause stalling because
you're already doing 5x5 Squats 3x/week. I urge you to stick with 1x5 Deadlifts."
"Never jump straight into your work weight, warm-up first. As an example, let's say your
work weight for the Squat is 135lbs. Then here's how your training would look like...
• 2×5 45lbs => 2 sets of 5 reps with the empty Olympic bar
• 3 x 90lbs => 1 set of 3 reps with the 45lbs bar + 22.5lbs/side
• 5 x 135lbs => first set of 5 reps with your work weight
• 5 x 135lbs => 2nd set of 5 reps with your work weight
• 5 x 135lbs => 3rd set of 5 reps with your work weight
• 5 x 135lbs => 4th set of 5 reps with your work weight
• 5 x 135lbs => 5th and final set of 5 reps with your work weight"
"Notice that on the Deadlift you only do 1 set of 5 reps, not 5x5 or 3x5 because that could
cause stalling when combined with 5x5 Squatting 3x/week. So let's say your work weight
on the Deadlift is 225lbs, here's then how it would look like:
• 5x 135lbs => 1 set of 5 reps, 1st warm-up set
• 5x 175lbs => 1 set of 5 reps, 2nd warm-up set
• 5x 225lbs => 5 reps with 225lbs, your work set"
No mention of power cleans
If you want to read the entire book that he sends
there it is.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
