I was going great til I got sick and when I finished week 8 with the 110kg bench it felt like I had more in me.
I think I'll give it one more week and if I can't get it out next week ill start all over again on the 125kg bench program seeing as my 1rm has gone up
We had our GPC Nats Qualifier on Sunday. After getting 60 lifters to our States, we had a heap more who missed out and therefore not qualified for Nats, so we held the Qualifier and got another 23 lifters. We may have 100 lifters at States in 2014.
Edited by markos
We had our GPC Nats Qualifier on Sunday. After getting 60 lifters to our States, we had a heap more who missed out and therefore not qualified for Nats, so we held the Qualifier and got another 23 lifters. We may have 100 lifters at States in 2014.Here are the results from Sunday
WOMEN
52kg class
Yvonne Wagstaff - 50.5kg - 60/40/102.5 - 202.5kg
56kg class
Sharnee Griffiths - 54.6kg - 82.5/50/105 - 237.5kg
Sharon Wilkins - 54.1kg - 65/35/120 - 220kg
67.5kg class
Nina Markopoulos - 61kg - 115/70/130 -315kg (72.5kg 4th bench)
Ariel Symon - 63.6kg - 90/47.5/100 - 237.5kg
Steph Finnin - 66kg - 75/37.5/100 - 212.5kg
75kg class
Shandelle Ross - 73kg - 75/55/120 - 250kg
MEN
67.5kg class
Aris Juico - 66.9kg - 165/112.5/195 - 472.5kg
75kg class
Allen Ozdil - 73.9kg - BMB/112.5/207.5 - BMB
82.5kg class
Albert Ozdil - 81.5kg - 212.5/132.5/230 - 575kg
Eddy Dargham - 82.5kg - 190/110/245 - 545kg
Sam Nayef - 81.6kg - 185/110/210 - 505kg
Andrew Johnson - 77.4kg - 155/85/205 - 445kg
Daniel Patience - 80.6kg - 150/90/170 - 410kg
90kg class
Dylan Hart - 89.2kg - 195/125/250 - 570kg
Rowan Pratt - 86.8kg - 110/95/182.5 - 387.5kg
100kg class
Jake Clinch - 99.6kg - 170/150/225 - 545kg
Fernando Serra - 98.5kg - 125/62.5/145 - 332.5kg
Brent Cosnett - 97.1kg - 70/65/65 - 200kg
125kg class
Michael Read - 120.9kg - 190/132.5/215 - 537.5kg
140kg class
Mike Vrljic - 132.9kg - 100/na/na - BMB
SHW class
Matthew Stockdale - 146.1kg - 150/85/205 - 440kg
BENCH ONLY
Fiona Morris - 63.4kg - 67.5kg bench
Mike Vrljic is H Bomb, the 2013 Australia's Strongest Man. He just performed a token squat to qualify.
Fixed up a bit of the formatting for you Markos, stupid SAU is broked lol
Just completed week 10 of the 165kg deads program, got 160kg out. Now just gotta step it up next week and pull 165.
The only part of PPP that has stalled for me is bench and feel like that might be partly technique related. By no means am I saying my squat or dead form is good, just not as big of a hinderance yet...
good work... you'll make that 165kg... just have to get a bit fired up, grab it and rip the shit out of it!
bench is tricky... it definitely doesn't progress as quickly as the other lifts... I'm still learning the technique
Its a skill you need to learn
Firing all your fast twitch fibres for a max effort is a skill
I have some lifters that need to learn to do 5 reps
Once your a complete lifter, you'll progress much faster
Zoran was awesome at singles, crap on 10's
Now he's much better, and much stronger for it
Got out the 165kg dead this morning! Didn't think it was going after I did the 157.5 before it and it felt tough but I got it up!
What happens when you finish that PPP program? Do you just pick a different weight and start again the next week or what?
Edited by Mitcho_7
did you read the PPP program?
It says do anything you like, just not that exercise
The cycles are 11 weeks long. You should get through 4 cycles per year. That’s 44 weeks,
which leaves 8 weeks. At the end of each cycle, I want you to do whatever you like, no
structure.
You can rest, do bodybuilding, train the whole body, curls for 2 weeks, it doesn’t matter. It
will allow you to freshen up your mind and body, this is very important. Go and jog for all I
care, you’ve earned it.
Edited by jangles
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
