Daniel America tore his pec in January, the tear was 3cm wide, 3cm deep and 3cm long.
He has reverted to reverse grip on his benching, and today benched 170kg. His PB was 167.5kg, the set before his pec tore in January.
He will bench over 180kg on September 8th at Melbourne Cup.
We have a comp at PTc on Sunday the 8th, GPC Melbourne Cup.
I have 3 new clients competing at their first sanctioned meet, Jason, Alex and Arthur.
This morning Jason squatted 200kg@75kg on his last heavy session before the meet
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
