PTC Eltham is opening this weekend.
PTC Canberra will be open shortly, equipment has been ordered/purchased, searching for a suitable location
Another PTC around Cairns next year
The boys at PTC Perth are looking at a opening a few more, surrounding Perth
We may have another north of Brisbane in 2014
Update on other events.
We had a Novice Comp in October, there were 44 competitors and between 200-300 spectators during the day
With the lifting, the girls this week
Heidi benched 90kg@66kg
Rebecca benched 70kg@60kg
Sussy benched 80kg@58kg
Rebecca squatted 140kg@60kg
Sussy squatted 135kg@58kg
Vicki benched 60kg x 3 @ 60kg
Vicki squatted 110kg x 2 @ 60kg
Arrione squatted 115kg x 5 @ 70kg, no wraps no belt
Arrione clean and pressed 60kg x 3
Arrione deadlifted off 7.5cm blocks 170kg
Ebony deadlifted 105kg @ 16yo
Ebony squatted 80kg @ 16yo
Katie squatted 90kg x 5 no belt no wraps
With the guys, we now have 3 that have deadlifted 300kg+, Jack 310kg, Zoran 305kg, Dan 300kg. Today Dan, Zoran and Martin are going for PB's, Martin should also pull 300kg making it 4 at PTC
Next in line is Roger who pulled 290kg last week and Spiros pulled 280kg, Albert also pulled 280kg at 17yo
Dan benched 190kg@125kg
Stelian benched 172.5kg@105kg
Max benched 170kg@90kg
Albert benched 170kg@100kg and 17yo
Martin benched 162.5kg@95kg
Martin squatted 260kg
Albert squatted 280kg x 2
Allen squatted 240kg@80kg
MENS ALL TIME RAW WORLD RECORDS
56kg class - 289/177/287.5 - 607.5kg
60kg class - 255/180/285 - 667kg
67.5kg class - 255/192/315 - 716.5kg
75kg class - 305/220/325 - 777.5kg
82.5kg class - 322/252/359 - 816.5kg
90kg class - 344/256/390 - 878kg
100kg class - 387/264/408.5 - 950kg
110kg class - 400/273.5/402.5 - 1000kg
125kg class - 400/295/400 - 1044.5kg
140kg class - 450/302/426 - 1072.5
SHW class - 453.5/322/460 - 1084.5kg
WOMENS ALL TIME RAW WORLD RECORDS
44kg class - 102/80/145 - 287kg
48kg class - 145/93.5/172 - 394kg
52kg class - 154/105/185 - 417kg
56kg class - 167.5/112.5/192 - 417kg
60kg class - 174.5/136/206 - 474kg
67.5kg class - 213/137.5/240 - 535kg
75kg class - 217.5/142.5/242 - 572.5kg
82.5kg class - 235/150/247 - 609kg
90kg class - 190/163/238 - 555.5kg
SHW class - 295/195/263 - 748.5kg
Haven't been on this forum in ages, very busy with work and any spare time I'm at the gym training
Training all lifts again, back seems to be fully recovered. Chiro was impressed with the time frame for my rehab. He figured I might be out a lot longer.
Training for the ProRaw ProAm at the moment, although just coming off a nasty flu that kicked my ass so not where I'd like to be. Just want to get another comp under my belt as I haven't competed since states. My goal was 600+ kg at 90kg this year, I'll go over 600 but my bodyweight is hovering around 92-93kg and I won't be cutting.
So after a really good start to the year it's been all over the place ever since. Hoping 2014 will be more consistent.
The new gym is awesome and some huge improvements from many lifters. Pretty amazing to watch really.
What kind of numbers are you looking at for each lift to go over 600?
I should squat around 230kg, bench hasn't moved since Nats (actually gone backwards if anything) so I'll be happy to press 140kg again and I should deadlift 250kg+... pulled an easy 240kg today
amazing my deadlift feels better than my other lifts and I really haven't been training it as frequently or as heavy as my other lifts... weird
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
