hi,
Car is a R33 gtst series 1
Car has been starting ok last few days with around about the 3/4 crank to start when cold
yesterday felt abit sluggish to start and similar today...
so i replaced the battery as had one good condition on the side..
as soon as i replaced it just dies and makes a ticking type noise from the engine..
so i put my old one back in and same thing again...so im guessing its no my battery as now it just doesnt even crank over but everything lights up..
have a power fc which says my voltage on 12.9 with everythging on but drops to 8/10v now wen turnoing the key and before was around 10/11v when trying to start..
could it be my starter or altenator...
im thinking starter...
its no even clicking over or turning....
any ideas cause need to know to get it fixed...
Edited by R33ram
https://www.sau.com.au/forums/topic/407506-starting-problem-help-asap/
i tryed jumper cables with another car and still dead slightly turned for a split second and then nothing just dead but,so im guessing not the battery is ok and defintley not the alternator cause doesnt get used to start the car but charge on start.....
O.K so was the jump car running when you tried to start the dead car?
When you say it turned for a second then stopped, was that the engine cranking or just the starter spinning?
If the car is in a spot where it is possible to do so, can you try and push start it? Get the thing running for a little bit then stop it and try to start it again.
If you can do this and it still wont start, something is going wrong with the starter, either the wiring or the starter itself is on the way out or already gone. So If this is the case I would check wiring first then if that looks all good then you might need a new starter. Check the resistance along the wire and see if its low enough (I wont give you an exact value, just report back) and check the resistance between the starter ground and the chassis to see if its low enough, again just report back
10-11v while the key is turned is enough to crank the engine over and indicates the battery is still O.K (without doing further testing)
Was the new battery you tried right for the job? was it the right CCA etc?
If it's dropping to 8/10v then it's your battery. They dont like cold weather. The other battery you tried is most probably dead also. You can still have 12v on the battery if it's nearly flat. It just wont be able to flow the current needed to start it.
Jump starting dosent always work if your leads are too thin. It wont get the current into the battery and it will have more volt drop.
Try as suggested and push start it or borrow a new battery.
Not using your car all the time can shorten the life of a battery. Aswell as having one sit in the shed doing nothing
The jumper starting car was started and running when the jumper cables where on mine..reved the car up a bit few min and left it running for a good 10min.
when to crank it over and just made like krrr krrr krr sound from somewhere in the engine and then just click click second time i turned the key then nothing at all bugger all.
Just before i put my battery on charger for a good hour or so and the again went to crank it over and nothing just that sound krrr krr krrr and a lil click and dead no sound again when trying to crank it over...and not even a enigine crank at all nothing just those sounds and thats it but then just does nothing like turning the key and silence.
ill check the wire to see and that if anything is going wrong..
You will need to charge your battery for a few hours an hour probably wont do anything.
I had an issue like that in my Swift. The starter motor would get stuck & then would just make a clicking sound.
Try putting the car in gear & then pushing it or rocking it just to get the motor to turn otherwise get a long breaker bar & tap the starter motor.
Hope this helps
Most battery chargers are 4Ah so it will take 20 hours to charge a 100Ah battery. I would be swaping for a new battery. It souds like at first the battery just has enough grunt to pull the contact in on the starter motor and tries to turn it then it drains the battery real quick. That is when you get the clicking.
It has enough guts to pull the contact in then it dies from the extra load on the battery at this time and repeats itself
All good guys changed it to a new one/starter and first crank started plus got to fix the hoses leaking water as the starter was why i couldnt see the leak were it was coming from..so got 2 things fixed for one :)..
thanks for ya help guys.
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
    • Thanks mate, well done to you too! Yeah not looking forward to doing any major work to it!
