Hi guys, first post on here.
Bought this beauty a month and a half ago (See below). Slowly things are going wrong.
- Warped front discs.
- Squeek from front left wheel. (Wheel bearing???)
- Squeek from the front when over various bumps on the road. (Co-worker said springs or shocks would be on the way???)
And now finally when accelerating out on a bend and got to around 3,000rpm and a knocking started. So pulled over, switched it off. Waiting 5-10 minutes started it up and it was still there so I decided to get it towed home to be safe.
$160 later the towie dropped it off half way up my long ass driveway and wasn't able to be pushed up the rest of the way so I reversed it the rest of the way. The knocking was there at idle but once it started to gain a little bit of speed while reversing it into the garage it stopped. Once back in park (Yes an automatic, don't hate) it started again. But I switched it off straight away. Locked her up and said good night.
Now the time has come to do something about it. I am an apprentice mech. But the fella's at work aren't giving my much help as they know nothing about imports.
So here I am. Has this happened to anyone here? Does anyone know what it could be?
P.s. A co-worker at my other job and old owner of my rig said it may be a coil pack and the knocking is because it's running on 5 cylinders.
Cheers, Nick.
https://www.sau.com.au/forums/topic/407622-knocking-noise-help-needed/
Need to clarify if it's a knock or a miss man! If you don't know yourself then record the sound and upload it so the guys have a chance to help...
Is the car shaking/missing? If that's the case it should be a simple fix hopefully...
Nope, if it's got a missfire it's probably coilpack or plug related.... My 34 did it (I think most do eventually), IF it is a missfire you have you can grab a set of coilpacks and plugs and be good to go.... You SHOULD be ok....
If your not confident and don't have anyone thy can help you diagnose just record it and post it to be sure I am not leading you astray ;)
Haha well I've got a 13 hour day tomorrow so I'll definitely post a video after work tomorrow.
Currently it's got quality NGK plugs and Splitfires. Would hate to think it's a coil pack. :mellow:
I filmed the car on but the file is apparently to big (16 point something MB).
DVS JEZ: It originally did it in drive, not keen on trying again in case it f@!?s it more that it already is.
Hadukeno: I was boosting it round the area with a couple of mates, nothing too crazy.
Just checked the oil, was just slightly low, nothing that seemed out of the ordinary for.
  • 1 month later...
Turned out to be the trans. The torque converter had actually seized onto the shaft inside the transmission. A replacement box was put in and it went away. 700 short of a manual convert. :(
Cheers, Nick.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
