Another variant would be to hold monthly SWAP MEETS, this way we could also get together, exchange ideas as well as parts... forum upkeep would be minimal as it only needs a sticky thread in the EVENTS section and it can be held at different venues around Sydney in order to keep everyone happy. I reckon it'd be more COMMUNITY like.
That's not a bad idea at all.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
