My hr31 has a twin turbo vh45. With the new ecu and a really nice tune its making 378.9rwkw. And there is not a need for any more on the street. Much time has been spent setting up the spring rate on the coil overs and camber adj to get the power to the ground. Now i can get the whole 380rwkw to the ground from 3rd gear. It is stupid fast.
That is awesome bro. I can only imagine how fast that thing would be
to be honest man, I would be content with 300kw at the wheels. no more than that. as it is, its quick, but not quick enough to be content.
Tomorrow is the day I get a power tune done. will update you guys :)
Back when everyone mainly ran 98 300kw was considered a fast power that everyone wanted now with e85 in the picture 300kw now is like 200kw used to be its nothing special with most people at the power level now its 380 plus being considered fast.
dude am I reading this correctly?
you've got a built engine but only standard injectors?
If so, you're missing out on some serious fun....
Yea man :(
short on cash. but it will be the first thing I get when I get some more cash.
420rwkw on pump fuel last year thru a auto :yes:
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
