Hi
i have installed a bosch 040 in my r34 gtt it is now also wired on it's own seperate circuit
everything works fine apart from the fact that after a few minutes of the car running the pump then develops this rather loud buzzing sound and left long enough the car won't get enough fuel to boost. the sound can be replicated by just started the car and letting it idle, it will happen after a while say a few minutes
if i turn the car off and start it again straight away the sound will continue straight away, if i turn the car off for a couple of minutes it will take a few minutes again for the sound to develop
when the sound is about to start i can hear like clicking/kind of slurping sounds almost coming from the pump, i'm thinking it is cavitation or turbulence with the bottom of the tank starving the pump maybe ?
this has been a bit of a saga for me over the past months with other shit going wrong so i'm about ready to buy a walbro and sell the 040 because i'm fairly over it heh
any help would br much appreciated
thanks
Edited by mystery_kid
https://www.sau.com.au/forums/topic/407797-bosch-040-in-r34-gtt-issue/
I had this exact issue and went through multiple pumps and eventually had to remove and clean the tank.
I know that buzzing sound all too well and had identical symptoms. How sure are you that it isnt clogged?
Sure as in pulled it out and looked at the mesh sure? Sure as in cleaned the mesh and checked it isnt clogged up again after you pull it out again sure? :P
Sure as in tried a different 040 and waited for that dreaded buzzing to happen again? The last thing you want (believe me) is to buy multiple pumps to find out the tank is infact full of shit.
Have you tested the pump flow out of the car? Unigroup Eng tested a new one in mine and the flow was starved.
There's a Bosch 040 thread under Just Jap forum.
There have been issues with this pump in past batches as you will read. Although 99.5% are just fine I'd estimate.
Just Jap sent my pump and others to Melb. Czechoslovakia didn't want to know about it. Melb tested mine and said it was OK.
I received it back in my original box (as I left a special mark on it); but the special mark I left on the pump itself was not there.
Just Jap were led to believe by Bosch that it was the same pump of mine that was sent there (Melb) for testing; but it was obviously a different/new pump that came back - and that's how they honour a warranty pffft
finally someone who knows what i am talking about
you know you're possibly right, i have pulled it out and there has been some black stuff on the mesh which i've cleaned off but other times i pull it out and it looks fine - really hasn't ever looked like enough to cause the issue
anyway i have ordered a walbro from just jap and i'm going to send the 040 back to them, they will send it away to bosch - so we'll see
i have had the pump running off a spare battery in the tank before for like half an hour trying to see if there was something in the tank blocking it and the sound never happened, but it wasn't getting a full 14volts off the spare battery
either way i've spent like 4 weekends now dealing with this pump issue since the old one died to where i am at now
I too took it out, cleaned the filter (it didnt look like enough to clog it but believe me it does) as I found out myself.
If you clean the filter, put it in, and it becomes clogged again, well the problem is not the pump.
My commiserations if you end up having to pull the tank in a backyard like me :P. I ended up with just a GTR pump (almost the same as 040) but holy shit is it loud. But as long as it works, who cares :P
Have you done the fuel pump earth mod? I'm sure the 34 is setup the same way where the fuel pump won't get full power at idle. Think it's dropped down to 9v or something when idling/off throttle. I was surprised to learn about it myself so did the mod and my pump sounds so much healthier especially when priming.
Just re-read your post, nevermind hahaha.
Edited by Akshunhiro
so i put a walbro in, all fine now
i'm just going try and manage whatever sediment is in the fuel tank, i put a new fuel filter in the other week so i will check that after 1 months usage and change it if need be and just use fuel additives for a while to do what i can
tanking the fuel tank out looks like a pain in the ass that i really don't have time for now as i'm about to be balls deep in my thesis and final semester of uni
thx bros
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
