G'day everyone,
Would like to get some advice from anyone that has removed an RB26 from a R32 GTR.
Long story short, a mate with a R32 GTR has got problems with a bearing (we think) so the motor has to come out so we can strip it down and find out exactly what it is. Other tests have been done, and we're pretty sure it's a bearing :D
Sooo, this Saturday we'll be removing the motor.
Is there any little tricks that would help us? Looking at it, it's going to be easier to drop the motor out the bottom with the gearbox assembly still attached, then remove the box assembly while it's on the ground etc...
Dropping it out the bottom, will we need to take the plenum or turbo's off?? Can we just take the turbo's off? The plemun looks like a pain in the butt to remove.....
We've got the workshop manual which we intend on using, but you know how it goes, there's always little trick that can save you hours in frustration.
Any help at all would be great.
Jayson
https://www.sau.com.au/forums/topic/40794-r32-gtr-engine-removal-advice-needed/
Hey Jayson
From my exp in taking out engines its probably easier to take it out from the top.
take off the ex manifold and turbos, undo the fmic piping, take out radiator, undo the aircon pump, take out the coil packs or wiring, undo the gearbox, undo the engine mounts then lift it out.
anything ive missed?
also jayson how easy is it to strip down a motor as ill be doing this on the rb30 block i have
Cool,
That's what we've done in the past, but the thing that makes me think about dropping it down is the tranfercase/4WD and front diff stuff, plus it takes a fair wack of time just getting the gearbox off the motor simply cause of the lack of space :D
Hmmm, we might have to take a good look at it etc...
Stripping down a motor is pretty easy once you've got the right tools (for the head etc..).
But you've got to make sure you take the head off correctly so it doesn't warp. Also have a big clean bench so you can lay everything out in the correct order (pistons, bearings, journals etc..), and if you think you may not remember how it goes back on, take a photo of it :)
J
yeah we took mine out thru the top as well, the left front drive shaft pops out easy, the right front is a real bastard. I think the hardest part was the bolts on the starter motor.
took about 4 hours in the end.
ive talked to phile from skyline perfromance he has just done two r32 gtr's in succession and he can do it in about 4 hours now but the first wont be that fast... what id recommend is undoing everything, then undo engine mounts...then rocking the front of the engine up and the take the gearbox off then pull the motor out.... it is so bloody hard to get them out in one piece man....
an engine jack? I dunno what its called but I've seen pics of RB26's being supported by this hydraulic jack looking thing with a long arm.
or you could do it the same way we did my mates V6, a big wooden stump and a 4 small jack stands
Guest two.06l
jackstands are the way to go resting the front crossmember on them and one for the gearbox.you can leave the turbos and inlet plenum on doing it this way.easier to remove gearbox and that bloody"starter motor".
perhaps off topic question: how do you raise a car without a hoist so you can use jackstands to hold up the engine and gearbox??
Also how much easier is it to do the wiring for the engine while under the car, and from above?
Guest two.06l
sorry did not realise he/she did not have access to a hoist
also much easier to wire up and plug in to loom
yeah thats what we used, engine hoist to lift it out the top. they're pretty snazzy, also used it to lift the car when the cheap sh1t floor jack broke :cheers:
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
