It Seems that heaps of guys on here and SDU have reported their engine stalling at low rpm, say as you approach an intersetion or your driveway and get on the clutch and allow the rpm to drop off, sometimes it drops so low that the car stalls.
POSSIBLE CAUSES:
While there seems to be heaps of possible causes I have personally found a way to solve it in my instance, I had the problem and now it gone, here's how.
Find the earth wire from the pump and cut it and run it directly to a good ground on some bare metal in the boot area......fixed.
Now it is possible that this may not fix YOUR problem but it did fix mine, that was until I pushed the power up and the pump could no longer sustain the fuel supply.
The reason this worked is because the R32 and the silvia's (possibly more) use a weird earth switch to the pump to keep it quiet at idle and low rpm. when the rpm drops say at idle the pump sent only half of its normal current, just enough to keep the pump going. By hard wiring it to the chassis you keep full current to the pump all the time.
I have done this on both a 180 and my car, both had the problem of stalling and now neither do. Give it a go, may save you the cost of the pump if it isn't the pump.
What you need:
Small phillips head screw driver
Small flat tip screw driver
large phillips head screw driver
wire snips
solderer
solder
heat shrink
hair dryer (do not use a lighter as you are working next to a fuel tank !!)
elecrical tape
sand paper
self tapping screw
electric drill with phillips head bit
about 30 minutes
Oh and by the way do not shine a torch into your fuel tank as most torches are not intrinsically safe and can cause your fuel tank to explode.
:wink:
Go hard.
Cam
  • Replies 242
A friend of mine and I were working in a silo doing some confined space cleaning (Good Money if you like the work) and another guy was wearing a cheap head lamp and after only 15 seconds in the space there was a big flash, we got very hot and very scared. Fortunately the vents had been open for 48 hours prior and most of the gasses had escaped.
So yes, torches can ignight fumes.
Cam
yeah reguarding the silo - its the dust that would have exploded - sounds really dumb but it happens :P - apparently a silo in europe took out a good portion of a hillside from a dust explosion. BOOSTMEISTER - reguarding the fuel pump - you say its negatively switched? - so when you ground it permanantly it runs on full speed ALL the time? - im not doubting that it worked for you but i always thought the stalling on idle was most often caused by the motor going temporarily rich on idle - not lean. but yeah youve contributed alot to the forum - good to have you here - your site always has some eye candy on it :D
Yeh, I can't explain it, but from what I understand the earthing wire is a bit dodgy and when your revs drop the pump cuts some of the voltage, now if the earth is not good then that drop may be a bit too much and actually stop the pump from well pumping....no fuel car stalls....
As I said this fixed mine and a mates so it MAY be ONE of the solutions..
Thanks for the compliment on the site....The silo was a hazadous waste storage silo that had been empty for 12 months and aired for over a Month, there was still some nasty gasses in there.
  • 7 months later...
It seems to happen to mine intermittently. Yeah as I approach the lights, I push the clutch in and the revs drop really low. Hasn't stalled yet, but really low like 400rpms, and it seems to be struggling. This particularly happens with the headlights on too. Can anyone comment on this?
Many seem to have problems with stalling and aftermarket bov's. Particularly on 33's it seems? Mine does it on occasion since installing a new bov. Doesnt bother me too much, once a week i can put up with.
Perhaps boostmeister had more chronic issues. Many thanks for the tip though! :)
Red17
This used to happen to me. At times can be very embarrasing and thats when it usually happened. What BOOSTMEISTER
says makes sense, cause that what it feels like is happening (surge). But i dunno. When i took it to UAS for a service i told them about it and they said it was just the throttle position sensor. The way they explained it to me was that all they do is connect the car to a computer and adjust things. So i dunno it is fixed now. I havent had it stall like that since.
Hey, I have the same problem as well!
My other problem is during take off from the lights. I have to ease into it, otherwise my car stalls (the rpms falls dramatically as I release the clutch). As a result, I usually have to rev the car to about 2000 rpm and slowly release the clutch. Any sudden release results in car stalling. Any ideas guys??
And no, its got nothing to do with my manual driving skills..i can drive!
My 180sx has a very similar problem. When I start it up it idles normally for about 30 seconds then it jumps from about 1500rpm to 500rpm and then after a while it stalls. Dr drift checked out the TPS and that wasn't the problem. I've swapped over a BOV and AFM from a working SR20 and that didnt fix it.
I don't know if they are related, but I also have a problem that sounds similar to cowboyb. If I release the accelerator and then go to press it again it's like the engine dies for about a second.
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW )
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
