Took my 32 to Wakefield a few months ago, and had a different brake issue. The car is v-spec ii, and was running brand new TRW GP 600 fluid with PMU club racer front pads (don't know what the rears are..). I would get 8-9 laps into a run, with no probs at all, solid pedal, stopping like nothing I have felt before then the next corner the pedal would go to the floor.. It would come back the second or third time, and it would stop hard when the pedal came back.. Knockoff seemed to be the obvious answer, but I would do 2-3 laps slowly to let everything cool, go to the pits, where sitting still it would do the same thing. 30 seconds without touching the pedal, straight to the floor, second or third press I would have a full pedal.. This happened 3-4 times, any ideas??
https://www.sau.com.au/forums/topic/408219-diagnose-my-brake-problem/
My money is on your master cylinder. Possibly brake booster as well, but I'll commit and say master cylinder. I'd suggest with the car off and parked, pump the brakes a few times and then hold them on firm. Does the pedal change feel or move at all?
You sure you are not boiling your brake fluid?
Was ALL the fluid changed? Might be worth a long bleed and top up with the high temp fluid. There may be old fluid in the system still.
That's my guess on most likely issue, particularly if you get a pedal back after a pump or 2. If it has boiled at some stage and left air bubbles, the first pump or 2 brings the pressure up then you have a reasonable pedal.
Unlikely to be pad knockoff in a skyline, they have good wheel bearings and don't tend to move much.
Sounds like it BUT its got the 600 stuff so it would be pretty hard to do? :/
True....it would be harder, but you can do anything if you try hard enough. I have boiled every 600+ brake fluid at different times over the years. Some last a little longer but it's not really that hard to get 600+ degrees in brakes. For what it's worth, I've found Agip to be the best, but these days I use motul because it is almost as good and cheaper (and I don't need that last 1/10th any more as I now have a better setup since some rule changes)
With boiling fluid I would have expected to feel some fade prior to the pedal going completely, have got all the old stuff out (used a whole litre of fluid on the day) we were bleeding it to get the pedal back as well, we are tying the PMU fluid next time, but will try the master cylinder test when it is running again. Brakes were rediculously hot..
Why would you expect to have fade prior to boiling the fluid? Fade is a pad issue not a fluid issue. The pad can be perfectly happy whilst the fluid is boiling its nuts off.
Bleed them again - you may well find the stuff comes out black. Usually does for me anyway.
Oh and get some ducted air onto the rotor/calliper etc.
Edited by djr81
Wrong wording, would have expected the pedal to feel a bit soft before going straight to the floor. All ideas so far were ones we had considered but none seem to line up 100%. Was hoping someone might come up with something left field. We will put some ducting, check out the master cylinder and run some better fluid next time
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
