Hi guys it has been awhile since my last cruise so i have decided to
create one. I know it's a bit selfish of me making it a friday morning because of my dayoff but we'l see if how many can or can't go and we can probably change the date and time but we'l see how we go first.
Meet Location - IKEA Springvale 917 Princes Highway Springvale VIC 3171 [parking level 2]
When: Friday 07/09/2012
10:30am for a 11:30am departure
Still undecided but theres 3 destinations I can think of.
Any suggestions would be great though.
Great Ocean Road, Phillip Island & Lakes Entrance
What to Bring: basically a full petrol and a good attitude.
You know how it is....good behaviour = fun and safe cruise....
https://www.sau.com.au/forums/topic/408234-meetgreetcruise-friday-07092012/
  • Replies 84
Set a route please - this is in the guidelines.
There is no way people are going to come if you say "we might be going to GOR, or PI". They are two ends of the state, add to the fact GOR from Springvale is madness. You wouldn't get back to Melb till 8pm at the earliest when you think we usually depart LARA at 10:30am and still don't make it back before 5pm on most occasions.
Yep will do but still undecided of where to go depends on who is definitely down though those were just examples but definitely will decide closer to the date so far it's for friday night just waiting for more responses.
That's only 6 days away >.>
Guest
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
