Hi guys it has been awhile since my last cruise so i have decided to
create one. I know it's a bit selfish of me making it a friday morning because of my dayoff but we'l see if how many can or can't go and we can probably change the date and time but we'l see how we go first.
Meet Location - IKEA Springvale 917 Princes Highway Springvale VIC 3171 [parking level 2]
When: Friday 07/09/2012
10:30am for a 11:30am departure
Still undecided but theres 3 destinations I can think of.
Any suggestions would be great though.
Great Ocean Road, Phillip Island & Lakes Entrance
What to Bring: basically a full petrol and a good attitude.
You know how it is....good behaviour = fun and safe cruise....
https://www.sau.com.au/forums/topic/408234-meetgreetcruise-friday-07092012/
  • Replies 84
Set a route please - this is in the guidelines.
There is no way people are going to come if you say "we might be going to GOR, or PI". They are two ends of the state, add to the fact GOR from Springvale is madness. You wouldn't get back to Melb till 8pm at the earliest when you think we usually depart LARA at 10:30am and still don't make it back before 5pm on most occasions.
Yep will do but still undecided of where to go depends on who is definitely down though those were just examples but definitely will decide closer to the date so far it's for friday night just waiting for more responses.
That's only 6 days away >.>
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
