What's going on fellas ?
Few of us have our display pics randomly disappearing, mines gone twice this week and it really is a hassle making new ones all the time, as was writing this letter. If this continues I may be forced to put in a claim for lost time and seek financial reimbursement if this isn't correctified soon. I have many witnesses to these events ,some of who may even be willing to testify if I pay them enough. I will then need to file for financial reimbursement for paying off my witnesses..
You see where I am going with this, it could get expensive quite quickly for you..For a man without a display pic, is hardly a man at all..
Regards
Disgruntled forum user
https://www.sau.com.au/forums/topic/408272-display-pics-keep-dissapearing/
I can understand maybe someone with a dirty mind could mistake my last picture of a girl drooling somewhat wrong...it was just drool btw not what others seemed to think it was..
But my previous dp was a picture "one man wolf pack" what's the excuse for that..and Luke had a picture of his car dissapear so please don't give me these cop out excuses and threats to ban when I have done nothing wrong...
Something is happening to peoples display pics, I would just like to know why.....
Doesn't matter if you didn't think it was or not - We deemed it to be (it was brought up by a Mod, so i removed it) and that's that. Boundaries are not there to be "pushed", because pushed, they tend to push back.
It's a forum that needs to be viewable by all users, in all workplaces and so on. Anything outside the wasteland needs to be appropriate or it gets removed.
As for legitimate pictures disappearing, that doesn't happen. It'll be the user doing it or trying to change it and getting it wrong, not Admin intervention. We have no need to alter something that is not outside the rules and from what i can see, it has not occurred.
  • 2 months later...
Semi related.
Tried to change my profile pic just now but it keeps coming back with "Failed to load new picture", the URL link doesn't work either, comes back with "Server could no be contacted"
Tried in 3x browsers, no difference.
Was not an offensive photo either.
This a bug of some sort?
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
