Hey guys, might be a silly question but I'm looking at options for my next project build. Just wondering how hard it is to get an R34 2door shell, straight or with repairable damage and what I'd be expecting to pay for one, the more complete the better, engine and box not needed. Or should I just look at buying a cheap 34 and selling the engine, box and whatever else i don't need?
https://www.sau.com.au/forums/topic/408464-r34-shell/
You'll pay $15k for a good GTT and recoup maybe $4-5k by flogging everything you don't need.
$10k for a rolling shell is pretty darn pricey. You might be able to find something with damage but it's likely a lot of the stuff you need will have been stripped (brakes, diff, lights, decent panels). This would probably be the cheapest option provided you can pull it straight and bolt panels back on yourself.
What project are you planning?
https://www.sau.com.au/forums/topic/408464-r34-shell/#findComment-6516373
Consider buying a VL Commodore shell, will cost about a tenth of the price of an R34 and you should be able to get info and parts for the conversion a lot easier, plus a VL sedan weighs as much as a 180sx (about 200kg less than an R34 GTT). You could also go VB to VK but you will need to run a fuel pump and lines for the injection. Just an idea.
Edited by *LOACH*
https://www.sau.com.au/forums/topic/408464-r34-shell/#findComment-6516532
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
