hi folks,
got a new problem with the car i haven't encountered before.. as a background.. my battery ran flat last week so after getting it recharged at the shop few days later.. i think i can hear det on light load.. i have a wideband wired in and on idle it used to be 14 odd now its constantly low 13 afr.. also when accelerating smoothly i can see my afr dipping into low 12 sometimes 11 on the afr gauge..
my suspect is the fuel pump failing due to the perhaps too much draw placed on it while i was using a semi charged battery.. could perhaps be the FPR, fuel filter or bad earth.. in either case.. im looking at changing the fuel filter and putting fuel pressure gauge in to check pressure this arvo
currently i have a sard fuel pump in there.. no odd noises.. primes fine.. no hesistation from the car.. i do have pretty bad fuel economy of late and car doesn't feel as nippy as it used to.. i have read past thread on dying fuel pump but would like to hear if i have missed anything out, will look at getting it on a dyno for a run but that could take a week
https://www.sau.com.au/forums/topic/408567-can-the-battery-kill-the-fuel-pump/
good point.. although i only run bp98.. the thing is i dont get the knock light flashing (pfc), so may not be getting picked up but sounds like det.. got half tank left, maybe drain it and put a fresh batch in..
when i had the car at unigroup earlier this year, yavuz did comment that its leaning out a bit at the top but wasnt sure if it was fuel pump or voltage or fpr
So it's running richer now than before?
Typically electric motors don't slow down after being subjected to low voltage high current situation unless its absolutely fingered and would barely work at all. But I would imagine all fuel pumps are brushless so makes it even more impossible
Exactly what I thought. It sounds like its running richer if anything now
11-12:1 AFR should be OK under load as long as your tune was done properly
right u are lads, running richer on idle n on boost (seeing low 11's), car never ran this rich so I'm about to clean the afms again n pressure test
not sure what the pinging noise is though, fuel pump -ve is grounded to chassis to bypass fpcm
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
