hey guys
i have been looking into this for quite a while, and im about ready to give up, i hear alot of cars having alot of flutter etc when changing gears etc...
and alot of people have been saying it the blow off valve, and alot of people are saying its turbo/compressor surge. just wondering which one it really is.. because hell i think it sounds cool, and would really like it on my r34. and if it is turbo surge, some also say its fine and some say it bad etc can anyone give me some more insight please?
any opinion and help woule be greatly appreciated
Conz
https://www.sau.com.au/forums/topic/408651-bov/
It is compressor surge and is caused by the bov. When the bov doesnt open at the right time or doesnt open enough the compressed air flows back across the blades of the turbo and out of the air/pod filter. This is often because of the spring rate in bov. It is not good for the turbo because the blades can get damaged and break and go through the engine. The flutter may sound cool between gear changes but its not worth it.
https://www.sau.com.au/forums/topic/408651-bov/#findComment-6520961
The R34 has a nylon compressor wheel which makes them lighter and quicker to spool... yet weaker under high psi/temperature. They're only good for about 10psi and are probably one of the worst turbos to experience compressor surge with. You could get the factory turbo hi-flowed, where they replace the inlet and exhaust wheels with steel. But even so, I wouldn't recommend compressor surge on any turbo.
https://www.sau.com.au/forums/topic/408651-bov/#findComment-6521860
There's a few different forms of surge most common is when the throttle and bov are closed while boost is still in the system with no where to go and it back tracks to the comp wheel and trys to stall it while the turbine is still being driven making that lovely flutter sound which is very bad for the turbo. It puts over 100 lbs of load on the thrust bearing which only has a 2mm contact area in some cases and so they fail quickly.
The other type (shown in the video) is a mismatch of compressor wheel in relation to setup as in its outside its efficiency zone or surge limit and it cant grab air to make boost if it gets to bad it can have a servere enough effect to brake cranks or engine mounts.
Pretty much most blow valves on the market today are crap inducing surge when the stock one worked perfectly fine there is others ways to do systems that dont need a blow off valve - red top RB20's/rb30 VL
https://www.sau.com.au/forums/topic/408651-bov/#findComment-6522997
This topic comes up once every couple of weeks, use the search function.
People are usually divided when it comes to whether turbo flutter is bad or not. Some people have been running fluttering turbo's for many years with no problem, others blow turbo's and quickly blame turbo flutter when it could have been many other reasons.
This is just my personal opinion, I have had a slight flutter on my ceramic turbo R34 at 12psi for 4 years now with no problem at all. I have read recently the smaller turbo's don't have the surface area that back pressure can damage as easy as larger turbos as the larger blades would be more susceptible to shear forces, but then others say the flutter in smaller turbos is dangerous. Whatever.
https://www.sau.com.au/forums/topic/408651-bov/#findComment-6526852
No one knows for 100% sure if it damages your turbo-charger. It is nothing more than a speculation.
All you have to do to get the sound is block off your blow-off valve. Instead of the air venting via the blow-off valve, it travels back through the intake across the blades of the turbine spinning forward. The resultant noise you hear is commonly referred to as flutter.
Don't listen to most of the tools here saying not to do it. If you like the sound, then do it. Nothing more than personal preference.
As stated, no-one can prove if it actually damages the turbine blades. XR6 Turbo Falcons do it from factory with nothing more than a pod-filter - you do not need to close the blow-off valve.
My brother had an R33 making 450rwhp, running a GT35R and a closed blow-off valve for the flutter sound. No problems ever reported there and that was over the course of 75,000km's.
It's quite simple; if you like the sound, do it.
  • Like 1
https://www.sau.com.au/forums/topic/408651-bov/#findComment-6527641
I had a few skylines one with a 35r forged engine etc and blocked off bov because the sound annoyed me had no dramas!
Also stock 25 with a 3076, blocked and that's still going with no dramas! Personal preference but on stock turbo set ups not worth it!
https://www.sau.com.au/forums/topic/408651-bov/#findComment-6527764
I tell people not to listen to the tools who tell them its ok to do it on their cars which cost them xx thousand. But what do I know? I happen to get my information from people who rebuild turbo's for livings and not off google.
So what if it didnt happen on your car, it may happen on his. And if you want to be the idiot who told him it was ok, thats on you.
https://www.sau.com.au/forums/topic/408651-bov/#findComment-6534212
good to know u get your info from people in the loop but gathering information and having it on your car is a different story, like i said, personal preference, your car do what you want!!!!!
his is stock, my set up was aftermarket and yes im the idiot who blocked my bov, BOO FU**ING WHO
https://www.sau.com.au/forums/topic/408651-bov/#findComment-6535611
  • 4 weeks later...
Meh, BOV sounds are good for one thing and one thing only, creeping up to bus stops when school finishes and all them kiddies are standing around, then as u get closer, boost it hard and blow it off righttttttt next to the bus stops. Hks SSQV/ Turbosmart Supersonic <3
https://www.sau.com.au/forums/topic/408651-bov/#findComment-6571668
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
