Hi Guys,
Im currently looking at buying a R33 GTST. Spending around the 8K mark and there are a few out there. A couple of nice 1996 series 2's i like but 1 has 120,000 but no rwc and the other is 180,000 but with rwc. Both look pretty similar with minimal mods.
Just curious what you guys think about R33's with high klm's ?? looking at the car being my semi daily drive and odd track day car.
Any help / opinions much apprciated.
Cheers Paul
https://www.sau.com.au/forums/topic/408703-buying-a-r33-gtst/
You can usually tell from the general look and feel of the interior what the 'true' kms would be. Ripped drivers seat, worn steering wheel, front dash, shift boot, any death rattles you here when you drive it, etc...
Remember to also check underneath the car as the rails and other parts that may have had abuse don't lie.
Like Hadouken said, if its got low k's it just for show. We all know these cars are brought to be driven not to be stored like a classic, (except for 1 or 2 exceptions, but not all,) so for a car 15 years + old they cant average 7500km/year. Im 'trying' :rolleyes: to sell my 33 and it doesnt have ridiculously low kms like most. My car was a daily driver except for 1 year when I was biking to work then that year it only averaged about 10,000km. High kays scare most people, but I think my car for instance, has proven itself with its reliability and it shows with the "normal" kays its accumlated over the years.
Other things to look for is if it has been looked after with regular servicing and quality products as well as what has already been mentioned.
The other way to look at it, if they (the cars your looking at) have true low k's you would have to wonder what the (motor/trans) internals are like from all the sitting around they have done with no lubrication and minimal start up and running.
Hope this makes sense.
Edited by YEE-HAA
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
