Hi Umair,
The banana 2.5Kg tub will cost $77.80 + freight (hopefully just over $6).
Regards, Terry
aah.. its about the same as my local supp shop
I might just go through them and save frieght.
Thanks for checking though!
far out, I never thought people actaully bought these bars.
Bag of natural or flavoured WPC, $20 from bulk nutirents. + your prefered carb source and flavourings, i do them at 30g protien per bar, Which make about 26 bars in total. Works out about 70c per bar.
Win win,
And if you wanna get real trickey, Get a bag of casien protien for that slow release night time bar :) Not to mention the amazing FLUFF that can be made.
Edited by sydking
James, finally a quote...
$9 freight to E Melb., so (for 2 cartons), only a couple of bucks more...
thanks Terry, so roughly about $109 for 2 boxes? Im abit strapped for cash atm but will definetly be getting some.
James, if youre after low carb protein bars that taste really good, the best I have tasted/sold are the Next Gen ones, around 2gm carbs with 18gm protein 55gm bar
The new protein balls are the balls, cherry flavour is superb, I cant keep enough of this product in stock
The mint flavoured balls have 1gm carb per 60gms
I think it works out James, to $96 for two cartons delivered :)
Anyway anytime :)
