  • Replies 72
Posted Images
So quite simple, who has the coolest numberplate, removing the (no doubt unstoppable) discussion on if having a personalised numberplate makes you a knob.
My plates read BCNR33. Got them with the car.
Saw BNR34T on an urban 4WD of some kind (Audi if I recall) the other night. lol'd.
Saw the plates FOMOCO on a Toyota Corolla today.
FOMOCO is the acronym commonly used for the Ford Motor Company, specifically their racing parts and muscle cars.
Edited by Amaru
Saw "BNR-33T" (nsw plate) on some kind of softroader. (pathfinder maybe???)
^^^I put this in the Plates that make you LOL thread.^^^
Coincidence ???
Flamin' Mongrels takin' all the good plates. NO FAIR !!!
Sinista's Plate is pretty damn fine as far as cool plates go.
Coincidence ???
hahaha as my post above, saw the same car :P
Was it 34T or 33T ?
Definately was NSW plates, but I can't be sure of model of car as I was still asleep on the way to work.
(dumbf**k o'clock)
I think it was redish ish in colour?? :blink: maybe...
regardless it was definately a WTF? moment. LOL.
Was it 34T or 33T ?
(dumbf**k o'clock)
It might be someone who used to own one and wants to keep the plates (for a future car maybe?) so has just chucked them on another car instead of paying to store them.
Wow, so BNR34T and BNR33T are both out there, being used on softroaders and not for their true purpose.
Makes baby Jesus cry. (he builds hotrods after all).
Tis a shame that these people do this and not pass em on but I guess a plate is just a plate.
A numberplate, by any other name, would smell as rich.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
